Eassos System Restore 1.2.3 na GAOTD
Eassos System Restore to rozbudowany a zarazem bardzo prosty w obsłudze program przeznaczony do tworzenia i przywracania kopii zapasowej systemu Windows.
Eassos System Restore is an easy-to-use software for system backup, disaster recovery and data protection purposes. It can quickly back up your system and easily restore it when anything goes wrong.
Both full backup and incremental backup are supported and multiple restore time points are available. The backup file can be password protected, which can avoid undesired system restore.
Całkiem udany program do backupu :ok
Wskazówka dla chcących zatrzymać program na dłużej.
Once you have registered it ONLINE,it will update "options.ini" file in the installation directory..
Just backup this file and you can install it registered (offline) on any computer later on...
(Install the program,don't launch it, copy options.ini to the installation directory.)
You can use any name+email with the registration..
