PrintHand Mobile Print Premium (android) za darmo
Download the app "App of the Day" and discover one new paid app, every day, free!
For upgrading you should tap Upgrade/Restore button in the free app — it is located at the bottom of the main page of the app. There will be option to upgrade using a promo code. We are experiencing extremely heavy load at the moment. So please be patient! You might need to try several times.
Print directly from your phone or tablet via WiFi, Bluetooth or USB cable without a computer.
Note: PrintHand app is NOT FREE. In order to print real pages, you’ll need to upgrade to Premium Mode by making in-app purchase. We recommend printing test page prior to upgrade.
You can print:
- Office documents (DOC, XLS, PPT, PDF, TXT)
- Images and photos
- Emails and attachments
- Web pages
- Calendar, call log, text messages
- Facebook albums
- Files from Google Drive, Dropbox, Box, SugarSync
- Content from business apps such as OfficeSuite, DocumentsToGo, QuickOffice, Exchange, EverNote and more via Share option
The app is similar to (and better than!) popular PrinterShare.
Printing to Mac or Windows shared printers, Workgroup, Domain and Active Directory and Google Cloud. Share the printer with our free software for Mac and PC from printhand.com, and print to any legacy printer as long as you can print from the computer. Our Printer Setup Wizard will detect your printers automatically, and guide through the configuration process if needed. In a few clicks you’ll be able to print.
Have a good print!
DTeXEQZhWR7r_e3BMYWHVxgZQH2hx-UpPSvNlWS81t-9de1wBWGxekfviTirhO84tPU=h310-rw
Vlj0inw_PrnScX5V-ZlLxrTcraVn8mMKuMCyWQ4_xTdiabVM-ep_ogy7D0FKcly5Ag=h310-rw
alco
XPgn0SlxVSUi8-dMbDJUBz5SrTINw7YugAgMX7IVbr3AiCb9Xzc9k4BTKccqqxw6yg=h310
Drukowanie z urządzenia bezpośrednio przez WiFi lub Bluetooth bez użycia komputera.
Uwaga: Program PrintHand NIE JEST DARMOWY. W celu wydrukowania prawdziwych stron należy dokonać aktualizacji do Trybu Premium przez dokonanie zakupu z poziomu aplikacji. Przed aktualizacją radzimy wydrukować stronę testową.
Można wydrukować:
– dokumenty biurowe (DOC, XLS, PPT, PDF, TXT)
– obrazy i zdjęcia
– wiadomości i załączniki
– strony internetowe
– Kalendarz, rejestr połączeń, wiadomości tekstowe
– Dokumenty Google
– Zawartość z wielu innych aplikacji, klikając na przycisk Udostępnij
– albumy Facebook
– Pliki z serwisu Dropbox
– Pliki z serwisu Box
– Pliki z serwisu SugarSync
Drukowanie na drukarkach udostępnionych na komputerach Mac lub w systemie Windows, w grupie roboczej, domenie i Active Directory. Drukowanie bezpośrednio za pomocą kabla USB z systemu Android 4.0 i nowszego. Drukowanie do Google Cloud. Współdzielenie drukarki z naszym darmowym oprogramowaniem dla komputerów Mac i PC z serwisu printhand.com i drukowanie na dowolnej drukarce, jeśli tylko można na niej wydrukować z komputera.
Nasz kreator instalacji drukarki wykrywa drukarki automatycznie i poprowadzi użytkownika przez proces konfiguracji, jeśli to konieczne. Za pomocą kilku kliknięć można będzie drukować.
Dobrego wydruku!
Adam_de
27 Luty 2015
Niestety, jakieś oszukaństwo :k......
android.giveawayoftheday.com pokazuje aplikację "PrintHand Mobile Print Premium", jest znaczek z przekreśloną ceną 10,60USD i napisem Free, natomiast link "Get the app" prowadzi do bezpłatnej "PrintHand Mobile Print".
Standardowy kod z giveawayoftheday nie działa :(
Nie wiem, czy jest możliwość zgłoszenia tego na giveawayoftheday lub bezpośrednio na printhand.com
alco
Coś w tym stylu. Promocja jak szybko się pojawiła tak szybko zniknęła. Może producent się wycofał. Nie wiem.
