Wusik MSTR is an Audio Analyzer and Multi Band Equalizer. The interface features a graphic overview of what the audio looks like under multiple frequency dividers. Starting from 20 HZ up to 20 KHz.
The main features are as follow:
- Multi band equalizer;
- Multi snapshots with overlay option;
- Regular audio input and also test noises and tones;
- Output limiter;
- Multi band frequency analyzer with scale option for each band;
- 3db / Octave analyzer;
- Two types of EQs per band;
- Pink noise mixing helper via the scale - pink noise - option;
- Resizable interface;
- File loading and rendering with option to loop all the file or portions. Plus, processing of all MAX values;
- Auto reset MAX values: after silence and new audio, every N seconds or when the RESET button is clicked.
