Mohammad.Poorya
19 Wrzesień 2018
On a Bike!
Corel PaintShop Pro to znany i ceniony program przeznaczony do edycji, zarządzania oraz udostępniania grafiki w sieci.
Corel PaintShop Pro 2020 22.1.0.44
Changes in Corel PaintShop Pro 2020 Update 1:
New/Enhanced items
  • SmartClone: You can now adjust the size and rotation of the selected clone source directly (you do not need to save it to the SmartClone library first).
  • More than 30 bugs resolved.
Issues addressed and changes
  • Text: Resolved stability issue when working with text on paletted images (2, 16, 256 colors).
  • Black and White 2-color images now retain color depth when saved and reopened in PaintShop Pro.
  • Windows for images (available when Tabbed Documents is off) now resize to match image size during cropping and zooming.
  • Depth of Field: Corrected zoom results issue.
  • Guides: Onscreen Guide (lines) positioning or deletion is no longer disabled when the Crop tool is enabled.
  • Display improvements: Improved text refresh to avoid incomplete text display, corrected dual-monitor menu issues, and switching tools no longer affects what area of the image displays (current view remains consistent).
  • Crop tool: Clear crop command on Tool Options palette now works when floating toolbar is off.
  • Default workspace: Resolved issue related to saving default workspace.
  • Guided Tour: Updated to reflect 2020 functionality.
  • PSD: Stability issues addressed for .PSD file saving.
  • SmartClone: SmartClone library no longer displays deleted images.
  • SmartClone: Resolved positioning issue that occured when working with a freehand smartclone source along the edge of images.
  • Creative Content installation issues addressed.
  • *.pspimage format issues resolved when working with different color depths.
  • Lens Correction message mismatch corrected.
  • Script toolbar: Stop button issue resolved.
  • Sony ILCE-6300 camera profile: Enhanced EXIF information visibility.
  • Refine Brush: History palette improvements.
What’s New in Corel PaintShop Pro 2020:
  • NEW Touch-Ready Photography Workspace
  • NEW SmartClone
  • NEW Refine Brush
  • FASTER Text rendering, editing, inputting and wrapping
  • ENHANCED Performance and user experience
What’s New in Corel PaintShop Pro 2020 Ultimate:
Includes PaintShop Pro + a bonus collection of software:
  • NEW GRFX Studio – Creative instant photo effects
  • NEW Parallels Toolbox – A suite of over 30 one-click productivity tools
  • PhotoMirage Express – Mesmerizing photo animation software
  • Painter Essentials 6 – Expressive photo-painting (64-bit)
  • Corel AfterShot 3 – RAW photo editing (64-bit)
  • Corel Creative Collection of brushes, textures and backgrounds
Mohammad.Poorya
19 Wrzesień 2018
On a Bike!
Corel Painter 2020 20.1.0.284 Update 1
Changes in Corel Painter 2020 20.1.0.284 Update 1:
If you experience any issues after installing this update, we recommend that you reset your workspace to ensure that all of the new features appear correctly. You can reset your workspace by holding down the Shift key when starting the application. A dialog box appears to confirm the restoration of the factory default settings.
Support for macOS Catalina (10.15)
  • Now when you choose a file format in the Save Image As dialog box, the correct extension is added to the filename.
  • The Append File Extension and Use Lower Case options in the Save and Export dialog boxes have been removed due to compatibility issues.
  • After you create a custom palette by pressing Shift and dragging brush variants from the Brush Selector to the document window, you can rearrange the brush variants or remove them from the palette as expected.
  • The installer no longer includes a driver that lets you select the Soundflower option and allows Audio Expression brushes to use internal audio.
Application Fixes
  • The application no longer stops responding when you:
    • run the Brush Accelerator test on some systems with NVIDIA graphics cards;
    • select, switch, and resize brushes;
    • select the Eraser tool or any other tool after applying and editing a gradient in the document window;
    • select a different gradient while working with Express Paint;
    • Corel Painter launches as expected on iMac 10.13.6 with ATI Radeon HD 4850 and ATI Radeon HD 4670.
  • If you apply a gradient in the document window, then click another tool in the toolbox, and then choose the Interactive Gradient tool again, the tool now functions as expected.
  • The Eraser tool now functions properly when you select a brush variant in a custom palette and switch back and forth between the Brush tool and the Eraser tool.
