Default Kerio Control 7.0.0 Build 896
Kerio Control (formerly WinRoute Firewall™) is a corporate gateway firewall for small and medium-sized businesses. Equipped with VPN server, optional embedded Sophos Anti-Virus, integrated customizable ISS Orange Web Filter, and user-specific Internet access management, Kerio Control provides a multi-layer architecture for protecting networks, servers and users. Kerio Control sets new standards in versatility, security and user access control. Designed for corporate networks, it defends against external attacks and viruses and can restrict access to websites based on their content.
Kerio has added a new IDS/IPS system. It plays an instrumental role in detecting and preventing application exploits and malicious traffic. It was developed by Kerio and is based on the industry-standard Snort project. Just like our built-in Sophos gateway antivirus, the IDS/IPS gets frequent automatic updates to ensure that networks are continuously shielded from emerging threats.
Intrusion Prevention System
• Signature based backet analysis
• IP blacklisting
• Rule management
ICSA Labs Certified Firewall
• Industry accepted standard test criteria
• Corporate level criteria - enforces default security policy immediately after installation
• Secure access remote administration - all changes to security policy are logged
Application Layer and Network Firewall
• Create inbound and outbound traffic policies.
• Protect servers without the need for a DMZ through application-friendly NAT traversal.
• Perform stateful packet and protocol inspection and logging.
Anti-virus Protection
• Filter viruses and worms from incoming and outgoing traffic.
• Simplify deployment with integrated Sophos engine.
• Dual anti-virus ready for extra protection and much more
Kerio Control 7.0.0 Build 896 Released
06.01.2010
Whats New:
+ New Intrusion Prevention System (IPS/IDS)
+ Added MAC Filter
+ Multiple IP addresses on an adapter
* License counting and policy changed
* Rebranding
+ DHCP scopes autoconfiguration (only available in the Kerio Control Administration web interface)
* McAfee Antivirus engine replaced by the new Sophos engine
+ VMware Virtual Appliance available in OVF format
+ Kerio Control Software Appliance: Added SCSI HDD drivers
+ Kerio Control Software Appliance: Added E100 network drivers
+ Kerio Control Software Appliance: Fixed 'winroute blocked for more than 120 seconds' error
+ Kerio Control Administration web interface: DHCP screen added
+ Kerio Control Administration web interface: Advanced Options screen added
+ Kerio Control Administration web interface: Logs viewer added
- Kerio Control Administration web interface: Fixed: Cannot set 0 MB/s as link bandwidth
- Kerio Control Administration web interface: Various design improvements and minor bug fixes
+ Kerio Administration Console: added link to WebFilter recategorization page
- Fixed: DNS forwarder does not work when WAN IP has been changed
- VPN Client for Mac: Fixed DNS problems on Snow Leopard
- VPN Client for Mac: Fixed: It was not possible to use some strong passwords
* Slovak localization was removed from administration interfaces
* Syslog: User cannot change Facility and Severity. These values are reset to Kerio defaults on upgrade. Check warning log after upgrade
* User cannot change paths to Control internal directories. These values are reset to Kerio defaults on upgrade. Check warning log after upgrade
* User cannot change paths to RAS before/after dial scripts. Kerio defined script names are used. Check warning log after upgrade
- Software Appliance: Fixed: Ctrl-C in Kerio Console can terminate Kerio Control
- Administration Console: Fixed: VPN IP Pool Dump crashes engine
- StaR: Fixed: Activity log was off by several hours in some time zones
- Fixed: Kerio Web Filter sometimes failed to categorize long URLs
- Fixed: NTLM authentication does not work if user name contains national characters
- Fixed: Random crash in login to Kerio Control Administration
- Added workaround in HTTP inspector for HTTP servers violating RFC by terminating headers with '0a 0a' (
- Fixed potential crash in communication with Domain Controller over LDAP
- Fixed potential memory corruption in HTTP protocol inspector
- Fixed: Kerio Control Software Appliance can crash if a lot of (20) IP addresses are configured on an interface
- Fixed: Kerio Control Software Appliance can crash if Safari browser authenticates using NTLM
More Info: Release History
Download: Kerio Firewall 7.0
