Narzędzia DriverMax Pro za darmo !
Jarom
23 Wrzesień 2016
Może dlatego, że pierwszy link to tak naprawdę tylko informacja o promocji taka sama jak te które są tu podawane? Nie wiem.
Natomiast ten link, jest inny niż te (widoczne) wcześniejsze:
marek7001
30 Lipiec 2012
Ostrołęka
Wszystko ok do czasu...Aktywuję konto Pro na maila, dostaję kod, aktywuję i po skanowaniu dostaję komunikat że muszę mieszkać w dojczlandach...
hakah
2 Listopad 2013
That license is given to German Residents and is not allowed to use by non German residents. I have installed and activated but after certain times you are reminded and the license is no longer valid.
Use German IP to activate.
hakah
2 Listopad 2013
If you are given the license after successful registration. you can use it to register and they accept it. After few hours later, you will receive a message reminding you are not German resident and not allowed to use that license. Then your license will then become invalid and insist you to purchase a license or use another valid license for replacement.
Later I will use your method to activate it and see what will be the result. Thanks for the advice!
hakah
2 Listopad 2013
OXYGEN THIEF: Yes, it works with German IP but it is surprised that my subscription now becomes 282 days instead of originally 362 days.
hakah
2 Listopad 2013
Today, I was informed that license is not allowed to use for non German residents and was subsequently deleted!
