Jarom
23 Wrzesień 2016
EZ CD Audio Converter 7.0.7
7.0.7
  • Read LAME 3.100 MP3 file gapless info
  • Gapless decoding of LAME 3.100 MP3 files
  • M4A metadata editing, now possible to remove tags from existing files
  • WMA metadata editing, now possible to remove BOOL and DWORD tags from existing files
  • Don't fail APE conversion on bad crc
  • AAC improved decoding of damaged files (improve syncing on bad frames)
  • M4A ISO gapless improvements (Converting M4A rips from sources like YouTube now work properly)
7.0.6
7.0.5
  • Fixed the memory allocation defect of v7.0.3/4 that sometimes caused a crash in sample rate conversion
  • Subfolders starting with a dot are now included when the parent folder is dragged to the audio converter
32 bit:
64 bit:
Jarom
23 Wrzesień 2016
EZ CD Audio Converter 7.0.9
7.0.9
  • Fixed loading of MP3/ID3V2 embedded images with unicode description text
  • Fixed Shorten (.shn) decoding
  • Added support for m3u8 (M3U UTF-8) playlists
  • Default padding block is now written to the created FLAC files to fix the playback bug of FLAC files in faulty firmware of some Pioneer and Onkyo receivers
    • Default behaviour of the official FLAC encoder
7.0.8
  • Monkey's Audio 4.33 codec update
  • Fixed a memory leak in video file audio decoder
  • Download 500x500 Cover Art from MusicBrainz by default
    • Better default size for embedded cover art
    • Smaller download - faster metadata query
    • High-resolution Cover Art download can be enabled from the Settings
32 bit:
64 bit:
Jarom
23 Wrzesień 2016
EZ CD Audio Converter 7.1
7.1
  • Performance improvements
    • All codecs and algorithm libraries recompiled and optimized with the latest C++ compilers
    • Notable performance improvements in most of the codecs (MP3, Vorbis, Opus, FLAC)
    • No change in audio quality
  • Bugfix: Decoding DSF file larger than 1GB failed
  • Bugfix: Adding a folder containing an m3u8 playlist to the Audio Converter added the same files twice
32 bit:
64 bit:
Jarom
23 Wrzesień 2016
EZ CD Audio Converter 7.1.1
7.1.1
  • Audio CD Ripper improvements
    • Added error detection compatibility mode that can be enabled for the drives that don't properly support the hardware-level error detection (C2 error pointers)
    • Improved error recovery
    • Don't stop on hardware-corrected read error in Normal ripping mode
    • Don't stop on hardware-corrected read error but report the data error in Error Detection ripping mode
    • Improved ripping/encoding performance by optimizing the CPU usage of the control thread and status window
  • Support converting Opus files with .ogg file extension
  • Don't crash when loading a FLAC file that has a corrupt (zero-length) metadata vorbis comment field
32 bit:
64 bit:
EZ CD Audio Converter 7.1.4
7.1.4
  • Codec updates
    • Vorbis updated to 1.3.6 with libogg 1.3.3
    • FLAC (1.3.2) updated with libogg 1.3.3
    • Opus (1.2.1) updated with libogg 1.3.3
  • Correctly detect and decode mono MP3 files that have (invalid) stereo VBR header
  • Always keep the original creation date of the file(s) on metadata update
  • Minor user interface improvements
32 bit:
64 bit:
EZ CD Audio Converter 7.1.5
7.1.5
  • Bugfix (critical): Previous update may have caused program to hang on Save Metadata under certain circumstances
  • Bugfix: Missing ID3v1 tag from MP3 file when Calculate ReplayGain enabled and AlbumGain calculated
  • Added choice to choose m3u8 or m3u format for saving file/track list
32 bit:
64 bit:
EZ CD Audio Converter 7.1.7
7.1.7
  • Codec updates
    • FhG FDK AAC encoder 4.0.0
      • Audio quality improvements
    • Monkey's Audio (APE) 4.34
7.1.6
  • Amazon Cover Art Search works again
    • Using the new protocol, because Amazon does not allow the use of Product Advertising API anymore
  • Improved multi-monitor support
    • Move app correctly between the monitors, remember the state of the window
  • Access MusicBrainz service with secure (https/ssl) protocol
    • All Internet connections are now secure except freedb that does not support it
  • Updated website links in the app
32 bit:
64 bit:
alco
8.2.2
8.2.2
  • Amazon Cover Art Search now works again (change in Amazon Search URL)
    • Higher resolution cover art from Amazon now available
  • Added BARCODE (UPC/EAN) and LABEL predefined metadata fields
  • Added context-sensitive Help buttons to Settings and Options
8.2.1
  • Replaced CD Ripper error detection compatibility mode with two error detection reading methods
8.2
  • Improved the Audio CD Ripper Secure Error Detection ripping mode
    • Now works and correctly detects read/sync/data errors with the drives previously failing with read/sync errors and extremely slow ripping speeds
    • Problem has occured with some drives manufactured by Lite-On (some of them rebranded as PLDS, Asus, Plextor)
  • UI improvement: Updated the integrated File Explorer
    • Added Quick Access (Windows 10) / Favourites (Windows 7/8) (if enabled in Windows File Explorer)
    • Navigate to/Select a file by typing the first letters of the file name
    • Improved appearance
    • Bug fixes
  • UI improvement: Track list and file list highlight focused item
  • Fix: Audio CD Ripper showed previous disc metadata if switching to Audio Converter or Disc Burner, changing the disc, and switching back to Audio CD Ripper
  • Codec update: Added WavPack 32-bit float PCM compression
8.1.1
  • Improved Audio CD Ripper track-selection checkboxes behaviour
  • Color error indicators in Audio CD Ripper status window
  • Cancelling CD ripping in Verify Audio mode now properly deinitializes the output file
  • Improved ripping speed of the Error Detection / Compatibility mode
  • Included critical LAME MP3 encoder bugfix (
  • Improved/fixed CD-R / CD-RW disc supported write speeds detection
  • Improved AIFF format to support 4GB files (previous limit 2GB)
  • Added Wave64 (w64) output format
  • Added Wave64 metadata support
  • Added AU (au/snd) output format
  • Reverted back a change made to the device access layer in v8.0.2 (may have caused drive communication problems in some systems with incompatible miniport I/O drivers)
  • Removed unnecessary drive seeking preparation (added in v8.0.2) prior CD ripping (may have caused ripping issues with some drives)
  • Updated language translations
8.1
  • Added AC-3 (ac3) encoder
  • Fixed Apple AAC encoder configuration ui for non-VBR formats
  • Automatic 32/64-bit file format for MPEG-4 ISO base media file formats (m4a m4b)
  • Fixed 64-bit WAV (PCM) (RF64) missing number of samples field from the file header
  • Support decoding Vorbis (ogg) files larger than 2GB
  • Restricted TTA file size to 4GB (TTA file format maximum size is 4GB)
  • Workaround for the Opus encoder bug in automatic Music/Voice detection in 5.1 channel mode with very low bitrates
  • Updated FFmpeg 4.1 (provides decoding support for various audio formats)
  • Reset free trial period
8.0.7
  • Set SoX sample rate converter as default resampler
  • Three SoX resampler quality modes: High, Very High, and Ultra High
  • DSD to lossless conversion with output sample rate set to 'Auto' now resamples to highest multiple, equal, or below 384 kHz
  • Improved SoX resampler performance by enabling the SIMD-AVX optimizations
  • All codecs recompiled with the latest optimizing Intel C++ 19.0 Update 1 compiler. Resulting minor performance improvements
  • Decode AMR (Adaptive Multi-Rate NB+WB) files
  • Decode THD (TrueHD) files
8.0.6
  • Added Audio Engine settings to the Options
    • Select preferred sample rate converter
      • SoX resampler
      • Opus/Speex resampler
    • Select sample rate conversion quality
    • Added Dithering options
      • Enable / Disable the dither
      • Select Rectangular, Triangular, or Noise-shaped
  • Smarter 'Auto'-selection of the output sample rate (for all output formats)
    • Automatically select the output sample rate that preserves the best audio quality (previously used sample rate multiples when possible)
    • Output sample rate can also be chosen manually for all output formats
  • Added 384 kHz and 352.8 kHz sample rate output for all lossless formats (except for WMA/lossless that does not support it)
  • Improved Opus encoder audio quality
    • Uses sample rate converter and quality selected from the Options for improved audio quality (Opus internally uses Speex resampler with quality level 5)
    • Configure sample rate converter quality from Options
  • Vorbis encoder update
    • Added manual sample rate selection
    • Now supports 192kHz, 176.4kHz, 96kHz, and 88.2kHz encoding
  • FhG FDK AAC encoder update
    • Now supports 96kHz and 88.2kHz encoding
    • More CBR formats for AAC LC and HE AAC v1
  • Apple AAC encoder update
  • Improved MP3 encoder audio quality
    • Better audio quality for output formats that require sample rate conversion
    • Let the LAME MP3 encoder to decide the best sample rate, but use sample rate converter selected from the Options for improved audio quality
  • Monkey's Audio v4.40 codec update
8.0.5
  • Fixed the bug where MusicBrainz query froze the App when MusicBrainz service returned malformed metadata entry. Bug occurred in very rare occasions.
8.0.4
  • Opus 1.3 codec update
  • Manual GD3 database search
  • Improved WAV metadata support
  • User interface improvements
8.0.3
  • Added option to save cover art to an external file in Audio Converter
    • Filename can be auto or specified (e.g. Folder.jpg)
    • Option to auto-resize
  • Added WAV dual channel L+R output mode (per user requests)
  • Other improvements
    • GD3 cover art search now works with ambersand (&)
    • Don't write Total Tracks metadata in Disc Image and Single File mode if it is disabled from the Settings
    • Case conversion is now also applied to Album Artist and Album Title
8.0.2
  • Improved the 'Verify Audio' ripping method
    • Sector by sector CRC comparison
    • Show number of CRC errors found
    • Log exact positions of CRC errors
  • Improved ripping log error reporting layout
    • Exact time position of an error at start of a line
    • Multiple errors in the same time position are reported on the same line
  • Added Eject and Close Tray buttons to the Disc Burner :)
  • Bug fix: 'Copy external Cover Art file' option now respects the setting
8.0.1
Following changes have been made in response to user feedback:
  • Put 'Delete source files after conversion' option back
  • Added 'Play' to Audio Converter list right-click menu
  • Cover Art 'Load' does not open the location of the currently selected audio file, but uses the default or last used location
  • Bug Fix: Audio CD Ripper creating an empty m3u playlist
8.0
Latest new features:
  • Metadata improvements
    • Windows Media Player online CD database (Gracenote)
    • Discogs online CD database
    • Discogs manual search
    • Discogs cover art search
    • Improved MusicBrainz manual search
    • Faster online metadata search
    • Option to limit metadata search results
    • Always uses secure (https/ssl) protocol to access metadata services (privacy protection)
    • Optionally auto-resize embedded cover art
    • Optionally save cover art to an external file (e.g. Folder.jpg)
    • Optionally copy external cover art when converting audio files
    • Added Conductor metadata to the main user interface
    • Get Conductor metadata from online metadata search
    • Advanced metadata editor to edit all metadata tags
    • Improved metadata search results list
    • Larger cover art thumbnails on metadata search windows
    • Resize multiple different cover arts in metadata editor with one click
    • Improved graphics on HiDPI / 4k displays
Built on top of the powerful audio framework:
  • Latest versions of the best audio codecs are included
    • All codecs are included out-of-the-box
    • Optimized for audio quality
    • Processor optimizations for best possible performance
  • Accurate 64-bit multichannel audio processing engine
    • Signal processing performed with 64-bit floating point precision
    • Up to 64 parallel converters
    • Optimized for best audio quality
    • Processor optimizations for fast performance
  • Accurate error-detective CD ripping engine
    • Hardware-assisted AccurateCDDA error detection and error recovery
32 bit:
64 bit:
alco
