FBackup 9.8 Build 815
October 19, 2023
- Added: New backup plugin for Spotify
- Added: New backup plugin for Studio One
- Added: New backup plugin for Moneydance
- Updated: Ensure the Supports Virtual paths is correctly set in new backup wizard for S3 compatible destinations
- Fixed: Error uploading to Google Drive root folder (when no folder was selected)
- Fixed: Smart backup was aborted if symlinks were found for backups from SFTP
- Fixed: Minor issue for mirror backups on Google Drive
- Fixed: Cannot switch between Dropbox Personal and Business in Online Connections options
November 20, 2023
- Fixed: Invalid backups for sources with Linux backslashes in filename
- Fixed: Renaming source folders on mirror backups returned warnings when running
- Fixed: Warnings after running mirror backups to Google Drive for files with split size set
- Fixed: "Open log folder" option was missing from the ribbon
- Fixed: Windows 11 Canary Channel was wrongfully identified as Windows 12
Changes in FBackup 9.9.846 (15-December-2023)
- Added: New backup plugin for AnyDesk
- Added: New backup plugin for RustDesk
- Updated: Danish language
- Updated: German language improvements
- Fixed: Root folders not found on mirror backup to be removed
- Fixed: Google Shared Drive was not visible in some situations
Changes in FBackup 9.9.849 (15-January-2024)
- Fixed: Error when defining new online connection via New Backup Wizard
- Fixed: Google Drive compatibility fixes
Changes in FBackup 9.9.853 (09-February-2024)
- Fixed: Error when restoring files from a smart backup in root of an external drive
- Fixed: Detection of invalid paths when backing up or restoring
- Fixed: Loading catalog on restore
Changes in FBackup 9.9.855 (16-February-2024)
- Updated: Compatibility with the latest Windows Insider Preview build
