GOM Audio
GOM Audio to bezpłatny i prosty w obsłudze odtwarzacz popularnych plików audio oraz stacji radiowych (wbudowana lista).Program obsługuje większość popularnych formatow audio, posiada wbudowany equalizer, pozwala na zmianę skórek i co ważne zużywa znikome ilości zasobów.GOM Audio może okazać się świetną alternatywą dla AIPMA czy Winampa.
GOM Audio 2.0.8.1130
Multi-language Support:
Spanish version added
Playlist Function and Feature Improvement:
The “When reloading the playlist, sometimes it will force the program to terminate.” problem has been fixed.
The problem of “During the use of multiple playlist tabs, if the current playlist tab is different than the tab you see, there will be an error when editing the tag from the main interface through the album art.” is fixed.
The problem of “The files that have once been played couldn’t be sorted.” is fixed.
When changing the size of the playlist, the items at the bottom will show correctly instead of showing half of them or turning blanks.
ID3 Tag Feature Improvement:
Fixed the ID3 tag’s error when the time information is included in the lyrics.
The error of the tag recognition appears when using an older version than V2.3 in ID3 tag is now fixed.
Shuffle Function Improvement:
When the “Clear current playlist and add new song (Play added song immediately)” in the preferences is selected, GOM Audio shuffles when adding multiple files by dragging into it instead of playing the first selected file.
When using the shuffle feature (including repeat all), the album art for the next song will match the actual song.
Playback Improvement:
The “Disable the repeat all feature, play the files in order and the program will be forced to terminate when finishing playing the last song” problem has been fixed.
Open with Default Program Improvement:
Fixed the issue of adding intro music and the problem in the preferences window when opening with the default program through Windows Explorer.
Other miscellaneous corrections, fixes, and improvements.
GOM Audio 2.0.11.1156
New Features:
Visualizer function
Keyboard options control
Upgrades:
Option to change playlist play order
Playlist playback function
Automatic alignment function when adding files
Keyboard or mouse wheel to change the volume
Other miscellaneous corrections, fixes, and changes
GOM Audio 2.1.2.6
New Features:
Synclyrics editor multiple run
GOM Remote connection
Playlist window resizing
Upgrades:
Synclyrics editing features and UI
Synclyrics shortcut key
alco
2.2.3.0
The default skin Equalizer window UI / UX improvements
Streaming playback even sound effects Support
Add the playback supported formats such as DSD (Direct Stream Digital)
Fixed an issue when a high-resolution monitor DPI settings layout is broken
Other bug fixes
alco
2.2.4.0
Add an audio icon to playable files
Add Korean Synclyrics automatic conversion function
Add 'Paste' mode in Sync Lyrics Editor
Fix error that certain formats were not played in Sync Lyrics Editor
Other bug fixes
GOM Audio 2.2.8.0
  • Improve Sync lyrics and fix errors
  • Added function to set time interval between playback songs
  • Improved multimedia keyboard volume control
  • Compressed files also provide stream information
  • Improve playlists and fix errors
  • Minor improvements and bugs fixed
