MediaMonkey 5.1.0.2827 Beta
December 8, 2023
  • Too much empty space on the add-on's installation dialog box
  • There is no space between "when sorting by" and "Artist, Album Artist, Album"
  • List view can loose selected tracks in specific cases
  • Playing YouTube video externally --> crash ABBB6FA3
  • HTML in 3-dot Playing menu [Regression]
  • Enhance 'Scroll to match' options
  • List (by Album) view: Updated album art fails to update in some cases (refresh problem)
  • Error dialog box is sometimes too big and it is always on the top of all windows
  • Case Checker changes Artist for CD with CD-Text
  • Multiple spaces not show in Filelisting
  • Online: Click on link in playing YouTube video --> crash
  • Playing internet radio freeze
  • DLNA play repeats playback from bookmark instead of beginning
  • Change in IP address breaks sync functionality until server is restarted
  • Auto-Tag doesn't work as expected with multi-value separator set to |
  • Global search for X returns Genre without 'X' in the name
  • Properties drop down do not get auto selected if only one result is available
  • List jumps when clicking on Rating to select file
MediaMonkey 5.1.0.2828 Beta​
December 17, 2023
  • Prepare MM for Windows 10 Desktop App Certification Program
  • User should be able to check what type of playlist synced to device
  • Zumocast crashes MM
  • Switch to micro/mini player button should be changed on Windows 11
  • BT Playback can't be initialized on BT headphones and WASAPI output
  • Some CUE files do not import correctly
  • First show of menus and especially submenus is too long when DebugView is on
  • Playback of files through NAS DLNA (Twonky) may skip files in some environments
  • MM cuts CD Burning to around 74 Min
  • Context menu fails on Summary when in List by View
  • "Ignore prefixes" controls don't have good flow when the Options dialog box is horizontally resized
  • Some controls are not disabled when their parent check box is turned off
  • The header of listview in "Add/Rescan files to the Library" doesn't have a look as other listview headers
  • Tabs should show tooltips with full paths
  • Context menus are selectively disabled for inaccessible tracks
  • List (by Album) - Performance optimizations
  • Two vertical scrollbars in main tracklist with Playing node
  • Allow edits in Preview panel is not remembered when switching skins
  • Album disappears from Grid by on Delete when No is selected
  • Minimal window size of program is too big
  • Adding files to Playing list causes removing of selections
  • Scrollbars in Options dialog box with double arrow buttons (Metro M skin)
  • Vertical scrollbar in main tracklist has double arrow buttons with Playing node, Album Art view (Metro M skin)
  • Selection fails to update when a context menu is active (regression)
  • All menu panels are moved several pixels to the right / below with maximized program
  • UI terminology consistency: 'Playing' list (and Files vs Tracks)
  • UI terminology consistency: Files vs Tracks
  • AutoPlaylist Criteria should show selection tooltip
  • Hard to find old value when many results are found in Auto-Tag
  • Program doesn't cover the entire screen when maximized
  • Playing list shows selected info in the status bar when none track is selected
  • Click on the down arrow button in the Preview title bar should close opened menu
  • Buttons (menus/tabs) in title bar with maximized program should be clickable when mouse is on the top of screen
  • Invalid resizing handle in listviews with restricted content width
  • Heigh of scrollbars are not consistent between main filelist and Playing
  • Checkboxes are hard to be skinned properly
  • Checking files in grid view is not intuitive and it cannot be skinned
  • Bidi Sync fails for recovery from a device or is erratic, whenever a device with an existing profile bidi syncs to a new PC
  • 'Sort by' field for Artist / Album Artist / Album
  • [MMW 5] Tagging / organizing (properties / auto-tools)
  • Auto-tag: takes much too long (regression)
  • Playcount is calculated twice when "Audio transitions" is "None"(Regression)
  • Tablet mode hides hamburger menu items on playback
  • Artwork tagging doesn't display correctly for non-library tracks
  • Tagging MP3 10s before the end leads to playback loop
  • Album Art view issues with Playing node
MediaMonkey 5.1.0.2832 Beta​
January 21, 2024
  • Artwork doesn't resize with panel width in Album Art view in Playing (first time)
  • The last ripped track not showing in 'All tracks' node until you press F5
  • Playing a problematic stream causes MM to go BACK to the previous track
  • Click on empty area below files in main tracklist should deselect all files in it (regression 5.1.0)
  • Unable to change bitrate for auto-convert rule [regression 5.1]
  • MM can freeze when doing constant inline editing
  • Missing files are not displayed in gray color on restart
  • File List addon can be uninstalled, but it is still shown in menu and can cause crash
  • Visualizer is hard to be skinned properly
  • Some icons in Toolbar list have diffrent width
  • Questionable pencil button in Grid (by Album) view of playlists
  • Properties: Original Title field is misleading since it actually usually refers to Original Album
  • Left panel menu item disappears from View menu
  • Right click on tab should not activate it
  • Auto-tag: images flash every time a new image is found
  • Search box unaccessible, tooltips missing, mouse wheel not working, after "Hide editor"
  • "Add location" menu is not aligned to the parent button in Add/Rescan
  • Removing file from Playing list selects wrong files
  • Drive letter mapped to local folder shows incorrect letter in Media Properties
  • Issue with duplicate drives after migration to the new PC
  • AV on D&D of files in Playing node
  • File list is not greyed out when no file is selected
  • Search doesn't include Podcast Episodes not downloaded
  • Hovering the menu scroll buttons should not show the sub-menu
  • Controls in Add folders dialog has different right alignment
  • Phantom nowplayingVerticalSplitter over maximized Visualization
  • Milkshake Visualization silently fails when Hardware Acceleration is disabled
  • "Add location" button should have down arrow icon or ">>" on its end, not ellipsis
  • Deleting file from Playing list [List (by Album)] takes long
  • Ability to read (and maybe write) registry values in JS needed
  • Waveform is hard to be skinned properly
  • HEOS players stopped advancing to the next songs (regression 5.1)
  • Add support for reading ORIGALBUM, ORIGARTIST, ORIGLYRICIST vorbis tags
  • Vertical scrollbar in Add/Rescan displayed when it shouldn't, depending on skin
  • Vertical scrollbar in main filelist displayed when it shouldn't, depending on skin
  • USB sync to Android device crashes to white screen for some users (regression in 2820)
MediaMonkey 2024.0.0.3005 Beta​
Mar 14, 2024
  • MediaMonkey 2024 appears as 'MediaMonkey 5' in firewall dialog
  • Temp folders don't identify as belonging to MediaMonkey.
  • Artwork metadata lookup causes focus from the active app to be lost for a second
  • Phantom Tree/Preview splitters over maximized Visualization
  • Error when switching to a downloadable language in MM 2024
  • Slider ticks are outside of their container
  • Sync to local folder: Re-syncing file without artwork adds extra seconds to the original file
  • Possible crash A14A6B74 on startup (build 3002)
  • Possible crash 87380000 during USB sync (due to Access Denied to Temp dir)
  • Installer windows don't have MediaMonkey Artwork
  • Choose highest 'quality' match in MediaMonkey when importing from streaming service
  • Current and remaining times are not updated simultaneously in player
  • Finalize 5.1 strings for translation
  • Rows on Details page in Properties dialog have inconsistent height
  • Casting to MMW: deletes playing list & stop button doesn't work
  • Album Art: Image Type should be easy to specify (regression)
  • Entering Alt + NumPad number also enters alt+value character
  • Inline edit of Album in Media Tree adds Album Artist to Album value
  • MediaMonkey 2024 installation do not remove Old Shortcuts
  • Data import from earlier versions of MediaMonkey
  • Possible crash A14AA4DF when closing dialogs
  • The first row in the Playing menu with Undo/Redo buttons should have different layout
MediaMonkey 2024.0.0.3018 Beta
Test notes:
  • This is pre-release software -- please backup your files to protect against data loss.
  • The debug build can experience issues when your machine goes to sleep.
MediaMonkey Installation:
  • Double-click the downloaded file and follow the installation instructions.
Looking forward to your feedback!
-The MediaMonkey Team
Download:
MMW 2024 Debug build:
MMW 2024 non-debug build:
