Monkey's Audio 10.42​
January 7, 2024
  • Fixed: Encoding files with the same name at the same time could fail to build an output filename because it would get a unique name then it could be gone by the time it used it. Now it tries again.
New in Monkey's Audio 10.41 (January 7, 2024)
  • NEW: Auto works for output filenames when compressing from the command line (just like auto for decoding).
  • Changed: Failures decoding legacy files better raises the actual error code (instead of just being undefined).
  • Changed: Made an internal change to the buffering readers to simply reject write calls (please report any issues).
  • Changed: Switched some variables to smart pointers (also internal change, but please report any issues).
l
Monkey's Audio 10.44​
Version 10.44 (January 23, 2024)
  1. Fixed: Building APE_INFO_WAV_TOTAL_BYTES was not working properly because it read the header and footer size before they were loaded.
  2. Changed: Updated to Visual Studio 17.8.5
l
Monkey's Audio 10.52​
Version 10.52 (February 28, 2024)
  1. Changed: Updated to Visual Studio 17.9.2.
  2. Changed: Split the Direct Show SDK off to a seperate library.
  3. Changed: Enabled Clang on the remaining Direct Show filter code and worked through the warnings.
l
Monkey's Audio 10.54​
Mar 11, 2024
  • Fixed: The DirectShow filter did not install 64-bit version properly so 64-bit DirectX programs could not find it (NSIS did not register 64-bit DLLs properly).
  • Fixed: Cleaned up the DirectShow Filter because it had some preprocessor defines causing problems in some configurations, also removed a pin name causing Clang warnings (MSDN said it was obsolete). Please report any issues.
l
Monkey's Audio 10.55​
Version 10.55 (March 12, 2024)
  1. Changed: Switched DirectShow Filter install to the InstallLib command in NSIS and removed the parts in the Monkey's Audio program (filters should still register, but please report any issues).
l
Monkey's Audio 10.60​
Version 10.60 (March 19, 2024)
  1. NEW: Switched to an open source code signing certificate.
  2. Changed: Updated to Visual Studio 17.9.3.
  3. Fixed: A compile problem on Gentoo Linux about casting the sample rate as a double.
l
