Monkey's Audio 4.91
Version 4.91 (August 23, 2019)
  1. Changed: Switched to mid/side encoding for four channel files for better compression (backwards compatibility broken, but only a few builds).
Version 4.90 (August 23, 2019)
  1. Fixed: Shutting down while processing could crash.
  2. Changed: Improved some of the channel code used for 6 and 8 channel files to be a little faster.
Version 4.89 (August 22, 2019)
  1. Changed: Switched the 24-bit code to mid/side for 5.1 and 7.1 files. Increases compression. Backwards compatibility broken, but again, only a few builds.
Version 4.88 (August 21, 2019)
  1. Changed: Switched to mid/side encoding for 5.1 and 7.1 16-bit files for better compression (backwards compatibility broken, but it's only a few builds).
Version 4.87 (August 21, 2019)
  1. Fixed: Added a missing 16-bit chunk of code to multi-channel decompression (files would fail to decompress).
  2. Fixed: Decompressing or verifying certain files could crash.
Version 4.86 (August 20, 2019)
  1. NEW: Support for more than two channel files (any number of channels less than or equal to eight should be supported).
Version 4.85 (August 20, 2019)
  1. Changed: Added experimental support for WAVEFORMATEXTENSIBLE files.
  2. Changed: Worked a little on not making the number of channels capped at two (still a long ways to go).
  3. Changed: A Visual Studio update.
Version 4.84 (August 10, 2019)
  1. Fixed: The size of MACDll.dll was bigger than needed.
Version 4.83 (August 9, 2019)
  1. Changed: A Visual Studio update.
  2. Changed: Reworked how the version is defined in the code and resources so it's only in one place.
  3. Changed: Revised the Winamp plugin install so it wouldn't have a double backslash (might not have mattered).
Version 4.82 (August 6, 2019)
  1. Changed: Replaced the watermark image with one a little better colored for some monitors.
Version 4.81 (July 28, 2019)
  1. Fixed: Install on XP was broken unintentinonally. I updated Inno Setup and they dropped XP, so I rolled back (
    appreciated).
  2. Changed: Moved all the versions in the resource files into the source include so they'll never lag by a build again.
Version 4.80 (July 25, 2019)
  1. Changed: Updated copy of Visual Studio 2019.
  2. Changed: Added 32-bit or 64-bit to the top of the about dialog.
  3. Fixed: The program will properly shutdown during install of a new copy of the program.
Version 4.79 (July 23, 2019)
  1. Changed: A couple cross-platform define corrections.
  2. Changed: An updated Visual Studio 2019.
  3. Fixed: Got a working resource file in the command line programs.
Version 4.78 (June 18, 2019)
  1. Fixed: APL parsing was crashing outside Windows.
Pobieranie:
Monkey's Audio 4.95
Version 4.95 (October 20, 2019)
  1. Changed: Made list auto-size fill the screen width if the auto-size resolves to less width that the list.
Version 4.94 (October 20, 2019)
  1. Changed: Made the size of the default run a little larger.
  2. NEW: Added the right-click command to auto-size all the columns.
Version 4.93 (October 15, 2019)
  1. Changed: A Visual Studio 2019 update for possibly better performance and reliability.
  2. Changed: Updated the copyrights to 2020.
Pobieranie:
Monkey's Audio 5.09
Version 5.09 (December 15, 2019)
  1. Changed: Visual Studio 2019 update.
  2. Changed: Added an example using "auto" as the filename to the command line program.
  3. Changed: Updated the copyright year in the help.
Pobieranie:
