Sketch Drawer Pro za darmo na SharewareOnSale
krzych533 napisał:Mam problem z kluczem pisze że wprowadzono nieprawidłowy kod rejestracyjny. Wie ktoś w co idzie?
Pobierałem program z Sketch Drawer na DSG
Podobne piszą userzy w komentarzach na Daily Software Giveaway. Może jeszcze zdążą wrzucić właściwe dane rejestracyjne. Do rana zostało trochę czasu.sonia napisał:Też mam problem z kluczem.
Tylko że ten wpis pojawił się na DSG dwie godziny temu. Wcześniej tej informacji nie było w komentarzach.kinimoD napisał:
Sketch Drawer Giveaway
Posted: 28 Nov 2013 11:11 PM PST
Turn your digital photos into works of art! SoftOrbits Sketch Drawer converts pictures to sketches in just a few button clicks and a few slider tweaks.
This photo to sketch converter produces a colorful hand-made drawing out of an ordinary photograph, laying accurate pencil strokes even if you can’t hold a pencil. Sketch Drawer makes converting photos to sketches fun!
Surprisingly, converting photos to pencil sketches is not that difficult even if you are not an artist. In fact, all you need to turn a picture into a sketch is a computer equipped with photo to sketch software. Sketch Drawer is fast, tiny and extremely easy to use. Open a picture, move the sliders until you like the result, and click “Save” to produce a wonderful pencil sketch!
Numerous presets are available to allow converting photos into pen or pencil sketches, creating color drawings or watercolor paintings in just a few moments. You can tweak each preset to create a drawing that matches your desired style just perfect.
Creating a wonderful colorful sketch with accurately laid pencil strokes could not be made easier. You don’t have to be able to hold a color pencil or even own one! All you need to turn a photo into a color sketch is Sketch Drawer.
Sketch Drawer allows producing color and black-and-white sketches equally easy. Draw with colored pencils by ticking the “Color Sketch” box to convert a photo into a color sketch, or clear the box to draw with a graphite pencil. Converting images to sketches and saving them as JPEG files will only take a few clicks and tweaks. Change photos to sketches with multiple art options.
Want a number of photos converted into sketches with all the same options? Turn photos into sketches no matter how many you have! The available batch mode allows Sketch Drawer to convert pictures to sketch easily even for beginners. In batch more, Sketch Drawer can convert a single picture or process entire folders. Just make sure to adjust all the settings before you begin, and you’ll be rewarded with a bunch of perfect sketches in just minutes!
W przedostatniej promocji programu Sketch Drawer został początkowo podany zły serial. Później wrzucono właściwy. Dzisiejsza promocja już działa.Emmers napisał:Uwga!!! Uwaga!!!
Klucze aktywacyjne z ostatnich promocji nie działają prawidłowo z instalkami z promocji ale...UWAGA!!! aktywują wersję ze strony producenta.
SPRAWDZONE
