Wise Care 365 Pro przez 6 dni na stronie:
The application is already unlocked which means you do not need a registration code. The program is automatically registered to Pro.
- You can use this giveaway license as long as you want, but no update and support.
Instalator:
grr
WISE CARE 365 PRO 4.26 (6-months license)
Techgravy partnership with WiseCleaner having Wise Care 365 Pro free giveaway to all reader.
Wise Care 365 Pro designed with easy to use interface and high functionality. PC users can use this software to clean up, speed it up and make it much smoother their PCs.
It can clean up invalid Windows registry entries, download and browsing history or clean the useless files on your PC that can significantly slow it down your PC. By the way, This application also add in optimization features that can tweak Windows to its peak performance.
This application compatible with Windows XP/Vista/7/8 or 10.
HOW TO GET WISE CARE 365 PRO 4.26 FULL VERSION
Just download this preactivated version of Wise Care 365 Pro and install it.
This software have been activated by WiseCleaner, so you don’t need license key to active.
Note: This version can support updating but has 6-month using time limitation.
Source
:hi
