Jarom
23 Wrzesień 2016
AllDup 4.0.23
AllDup jest darmowym narzędziem do wyszukiwania i usuwania duplikatów plików na komputerze z systemem Windows. Algorytm szybkiego wyszukiwania umożliwia znalezienie duplikatów dowolnego typu pliku, np. plików tekstowych, zdjęć, muzyki lub filmów.
AllDup Version History
4.0.23
  • NEW: Hungarian translation of the user interface. (Translator: Döbröntei Sándor)
  • FIX: Various optimizations have been introduced in various sections of AllDup. Various bugs have been fixed.
4.0.20
  • NEW: Traditional chinese translation of the user interface. (Translator: StarOS)
4.0.18
  • NEW: French translation of the user interface and the manual. (Translator: JP.Quélo)
4.0.14
  • NEW: Search Result / Menu bar / Options: Added the option 'Show prompt to save search result on exit'.
  • UPD: Saving the search result was optimized and is now faster especially when saving a huge amount of data.
  • UPD: File- and Folder filter list: Now you can edit a filter via the F2 key.
  • UPD: The interaction with the user interface via the keyboard was optimized.
4.0.12
  • NEW: General Options: Added the option 'Check for new update once a day'.
  • NEW: Search Result / Toolbars: Now you can hide or show each button of a toolbar via the context menu.
  • NEW: Search Result / Toolbar: Added the buttons "Show previous selected file" and "Show next selected file".
  • NEW: Search Result / Menu bar / Remove: Added the command 'Remove all groups with all files selected'.
  • NEW: Search Result / Menu bar / Select: Added the command 'Select files by path' and 'Deselect files by path'.
  • NEW: The progress of the scan for duplicates will be shown at the windows task bar inside AllDup's task button as an animated progress bar. (Windows 7 or higher)
  • NEW: The Internet Update Wizard is now also available at the Portable Edition.
4.0.10
  • NEW: Source Folder: Added the compare methods 'Compare files from all source folders' and 'Compare only files between different source folders'.
  • UPD: The progress info during the scan for duplicates was revised.
4.0.8
  • UPD: The estimated remaining time and the progress will be shown a the window title when load/save a search result or expand/collapse a large amount of groups at the search result.
  • UPD: Search Options: The option 'Determine the file attributes (slower)' was removed.
  • UPD: The Russian translation of the user interface was updated.
4.0.7
  • NEW: Search Method / Option: The new option 'Don't compare hard linked files' prevents the content comparison and the checksum creation of files which are hard links of themselves.
  • NEW: Search Options: Added the option 'Remove all groups where the files do not exist in all source folders'.
  • NEW: Search Result / Menu Bar / Options: The new option 'Show file info icons' will show a special icon for hard linked files and files from inside an archive at the left edge of the search result.
  • NEW: Search Result / Menu Bar / Options: Added the option 'Text color of reference files'.
  • NEW: Search Result / Menu Bar / Options: Added the option 'Text color of compressed files'.
  • NEW: Search Result / Menu Bar / Options: Added the option 'Text color of hard links'.
  • NEW: Search Result / Menu Bar / Options: Added the option 'Background color of groups'.
  • NEW: Search Result / Menu Bar / Options: Added the option 'Text color of groups'.
  • UPD: The options to filter files by size has been moved to the file filter pane.
  • UPD: Search Options: The layout of the options has been improved.
  • UPD: Search Result: A mouse click with the right button on a column header sorts only the files inside a group.
  • UPD: Search Result: Now you can use the hotkey F2 to rename files.
4.0.5
  • NEW: Search Result / Context Menu 'File': Add the command 'Rename file'.
  • UPD: Command-Line: Folder paths without space(s) don't have to be enclosed in double-quotes anymore.
  • UPD: Now you can use the hotkey F4 to start the search for duplicates.
  • UPD: Profile List, Source Folder List and Stored Search Result List: Now you can use the hotkey F2 to rename items.
  • UPD: Search Result: The created picture preview of a group will be cached until a new group is selected.
  • UPD: Stored Search Result List: Added the columns 'Duplicates' and 'Search Criteria'.
  • (!!!): The stored search results of the previous version can't be loaded anymore.
4.0.3
  • UPD: Search Criteria 'Similar Pictures': At the file preview of a group the column 'Match' will be shown.
4.0.2
  • NEW: Command-Line: The command -s9 starts a search with the search criteria 'Similar Pictures'.
  • NEW: Command-Line: The command -h[0-2] enables you to specify the comparison method for the search criteria 'Similar Pictures'.
  • NEW: Command-Line: The command -m[1-100] enables you to specify the percent match for the search criteria 'Similar Pictures'.
  • NEW: Command-Line: The command -d[0-2] enables you to specify the compare size for the search criteria 'Similar Pictures'.
  • NEW: Search Result / Menu Bar: Added the menu entry 'Columns' to hide/show the columns at the search table.
  • UPD: Search Result / Menu Bar / Options: The option 'Display user selected files in bold' was replaced by the option 'Background color of files selected by user'.
  • UPD: Search Result / Menu Bar / Options: Now you can specify an individual color for the background of selected files.
  • UPD: Search Criteria 'Similar Pictures': Comparing the hash values was optimized and is now much faster than the previous version.
  • UPD: Search Criteria 'Similar Pictures': Files with 0 bytes will be automatically excluded from the search.
  • UPD: The number of all excluded files and folders from the search will be shown at the log.
4.0
  • NEW: The user interface was revised and equipped with new icons, arranging the program in a clearer manner.
  • NEW: The Unicode-Compatibility was overall improved. Text with Unicode characters from languages such as Chinese, Japanese, Korean or Russian will be displayed properly.
  • NEW: According to our measurements, the search by file content is now up to 50% faster than the previous version.
  • NEW: The new search criteria 'Similar Pictures' enables you to find similar or almost identical pictures between the image file formats BMP, JPG/JPEG, GIF, PNG and TIF.
  • NEW: Search Method / File Content: The search by file content supports now the checksums MD5 (128-bit), SHA-1 (160-bit), SHA-2 (256-bit), SHA-2 (384-bit) and SHA-2 (512-bit).
  • NEW: Search Method / File Content: Added the option 'Ignore metadata of FLAC files'.
  • NEW: Search Method / File Content: The option 'Ignore ID3 Tags of MP3 files' ignores now the tags 'Lyrics3 v2' and 'APE v2'.
  • NEW: Search Method / File Name: Added the option 'Partial name matching of not less than x percent'.
  • NEW: Search Method / File Name: Added the option 'Compare only characters at the beginning of a file name'.
  • NEW: Source Folder List / Options: Added the option 'Compare only files within the same source folder'.
  • NEW: Search Options: Added the option 'Show only files without duplicates at the search result'.
  • NEW: Search Options: Added the option 'Log every x minutes the search statistic of the scan progress info'.
  • NEW: Options / General: Added the option 'Unicode-Text Support'.
  • NEW: Options / General: Now you can choose between 19 different color themes for the user interface.
  • NEW: Options / Log: Added the option 'Log all non-duplicate files'.
  • NEW: Options / Search Result: Added the option 'External program to open a folder'.
  • NEW: File and Folder Filter: Now you can specify multiple filters using the special character '|' as a separator. Example: *.bmp|*.jpg|*.jpeg|*.png
  • NEW: Search Result: The new option 'Select Mode' enables you to choose what groups will be affected from a select/unselect action.
  • NEW: Search Result: Now you can re-arrange the column order via drag & drop.
  • NEW: Search Result / Menu Bar / Select: Added the action 'Expand all groups contain files with different names'.
  • NEW: Search Result / Menu Bar / Select: Now you can choose between the modified and created date at the select action 'Select all files except the newest/oldest file'.
  • NEW: Search Result / Menu Bar / Options: Added the option 'Resize column width of all rows'.
  • NEW: Search Result / Menu Bar / Options: Added the option 'Hide all toolbars'.
  • NEW: Search Result / Menu Bar / Remove: Added 'Remove all groups with x file(s)'.
  • NEW: Search Result / Menu Bar / Remove: Added 'Remove all groups where the files not exist at all source folders'.
  • NEW: Search Result / Toolbars: Now you can hide each toolbar via the context menu.
  • NEW: Search Result / Toolbar: Added the buttons 'Show previous/next non-selected file'.
  • NEW: Search Result / File Context Menu: The action 'Copy to the clipboard' enables you to copy the file name and/or file path to the clipboard.
  • NEW: Search Result / Toolbar / Search: Added the button 'Search Options'.
  • NEW: Search Result / Toolbar / Search: Added the option 'Case-sensitive search'.
  • NEW: Search Result / Toolbar / Search: Added the option 'Use wildcards'.
  • NEW: Search Result / Toolbar / Search: Added the option 'Search all visible columns'.
  • NEW: Search Result / Toolbar / Search: Added the option 'Wrap the search after reaching the end or the beginning of the search result'.
  • NEW: Search Result: Clicking on 'Search Result' will show up the search log at the file preview pane.
  • NEW: A log window will be displayed at the search progress.
  • NEW: File and Folder Filter / Context Menu: Added the actions 'Escape wildcards' and 'Unescape wildcards'.
  • NEW: Command-Line: The command -c enables you to specify the compare method for the search criteria 'file content'.
  • NEW: Command-Line: The command -n prevent that the passed folders will not added to the source folder list.
  • UPD: Source Folder List: Now the user can add and remove drives.
  • UPD: Source Folder List: Now all existing drives will be added to the list only at the first start of AllDup.
  • UPD: Search Result / Toolbar: Now you can search forward and backward at the search result.
  • (!!!): The stored search results, profiles and program settings of the previous version 3 will not taken over to the new version.
  • (!!!): Windows 2000 is no longer supported.
Wymagania systemowe
AllDup jest zgodny z 32-bitową i 64-bitową wersją następujących systemów operacyjnych:
- Microsoft Windows Server (wszystkie wersje)
- Microsoft Windows 10 (wszystkie wersje)
- Microsoft Windows 8 (wszystkie wersje)
- Microsoft Windows 7 (wszystkie wersje)
- Microsoft Windows Vista (wszystkie wersje)
- Microsoft Windows XP (wszystkie wersje)
W sprawie spolszczenia proszę się zwrócic do Kolegi @fresta pisząc w tym temacie: https://programyzadarmo.net.pl/threads/alldup-spolszczenie.16123/
To zdaje się że ok. 750 linii tekstu do przetłumaczenia.
fresta
8 Październik 2010
Dokonałem część tłumaczenia (co prawda nie po kolei). Może ktoś by podjął się dalszego tłumaczenia, chętnie prześlę plik.
Jarom
23 Wrzesień 2016
To tłumaczenie które robisz jest w pliku *.txt czy w *.dll :??
Jarom
23 Wrzesień 2016
AllDup 4.0.28
4.0.28
  • NEW: Italian translation of the user interface and the help file. (Translator: Gennaro Esposito)
  • NEW: Polish translation of the user interface. (Translator: Fresta)
  • NEW: Search Method / Comparison Criteria 'File Name': Added the option 'Ignore characters at the end of a file name'.
  • UPD: File Filter / Option "Exclude files by size": Added the size units GB and TB.
  • UPD: File Filter / Option "Exclude files by size": Now you can specify a file size with a maximum of 6 digits for each size unit.
Jarom
23 Wrzesień 2016
AllDup 4.0.40
  • NEW: Comparison Criteria 'File Content': The compare method 'Byte by byte' has been extended by the option 'Percentage Match' to find files with a similar content.
  • NEW: Arabic translation of the user interface. (Translator: Mfm Dawdeh)
Jarom
23 Wrzesień 2016
AllDup 4.0.42
4.0.42
  • NEW: The location of the AllDup application data will be displayed at the options.
  • UPD: The french translation of the user interface has been updated.
AllDup 4.0.44
4.0.44
  • NEW: Portuguese translation of the user interface. (Translator: Havokdan)
  • NEW: Slovenian translation of the user interface. (Translator: Jadran Rudec)
  • UPD: The Russian translation of the user interface has been updated.
AllDup 4.0.47
4.0.47
  • NEW: Finnish translation of the user interface. (Translator: VeikkoM)
  • UPD: The traditional chinese translation of the user interface has been updated.
  • UPD: The slovenian translation of the user interface has been updated.
AllDup 4.1.0
4.1.0
  • NEW: Comparison Criteria 'File Name' / Option 'Find similar file names': Now you can select the algorithms 'SmartMatch', 'FuzzyMatch', 'Levenshtein', 'Ratcliff', 'MatchDiff', 'WordMatch', 'FuzzyPercent' and 'Simil' to find similar file names. See examples at the help file.
  • NEW: Search Options: Added the option 'Abort the search operation after a certain amount of duplicates was found'.
  • UPD: Comparison Criteria 'File Name': The option 'Partial name matching' was renamed to 'Find similar file names'.
Ponieramy na stronie:
AllDup 4.1.2
4.1.2
  • UPD: The portuguese translation of the user interface has been updated.
  • UPD: The russian translation of the user interface has been updated.
AllDup 4.1.5
4.1.5
  • NEW: Greek translation of the user interface. (Translator: Pandelis Zeniodis)
  • UPD: Now you can delete files from inside a zip file with the file manager.
