COMODO System Cleaner / System Utilities - wersje stabilne
LanceNDZ
5 Lipiec 2010
Katowice
COMODO System-Cleaner 3.0
Pojawiła się nowa wersja COMODO System-Cleaner do pobrania tu->
Main features
Registry Clean. Remove any corrupt or unnecessary registry entries.
Disk Clean. Boost your PC's speed by cleaning out its junk. Delete duplicate files and needless archives.
Privacy Clean. Protect your privacy by removing all your privacy traces from the system.
Delete locked entries. Delete locked files and registry entries using Force Delete.
Shred your personal data. Permanently remove files, partitions and entire disk data with Shredder, in order to protect your privacy.
Easy-to-use GUI. GUI just got easier to use. Use our default cleaning profiles or create your own. Cleaning your computer is just one click away.
New features
Registry monitoring. You can get instant scan results to registry entries also.
Force delete. You can now delete not only locked files but locked registry entries also.
Improvements
Best scan speed. Get instant scan results with our monitor driver. Cleaning has never been faster.
Better clean speed. Improved clean engine, with 30% boost in performance.
Innovation & technology
Active Clean. Select "Active Clean" mode and you will never have to press a button. System-Cleaner will do the clean for you.
Smart cleaning profiles. Define your own profiles for the best cleaning experience.
Benefits
Backups. Backups are made using COMODO Backup API. You can restore them either from Comodo System-Cleaner or Comodo Backup.
Updating database. Every day improved cleaning experience by constantly updating out cleaning database.
Update to BETA. Keep in touch with all new versions by updating to BETA versions (optionally).
One click feedback. Tell us if you like/dislike our backup system cleaner by clicking on feedback button.
Re: COMODO System-Cleaner 3.0
dzieki, jutro pobawie sie tym programem:)
martini
to ja sie dołączę.. czy niema już wersji bez instalacyjnej?
Programik całkiem całkiem, w wersji 3 bardziej pełen automat.
LanceNDZ
5 Lipiec 2010
Katowice
program faktycznie automat - niezauważalny ale robi to czego się od niego oczekuje, active clean działa całkiem przyzwoicie
wersja portable jest zapowiedziana wraz premierą CSC 3.1 niestety bez informacji kiedy to nastąpi
The portable version will be available in CSC 3.1. It requires a lot more work than 2.2 version because CSC 3.0 is based on instant scan and active clean, and this operations are performed with the help of a system driver. We can't have drivers in the portable version ...
Re: COMODO System Cleaner - wersje stabilne
COMODO System Utilities 4.0.226743.26
