- Dołączył
- 25 Czerwiec 2017
- Posty
- 198
- Reakcje/Polubienia
- 2085
Homepage:
Downloads:
Direct Download:
O.S. Supported: Windows PC/Windows Servers/Linux (UEFI BIOS)
FAQ:
What is EFI System Cloner?
EFI System Cloner is pure EFI based system cloning software. It can be used to backup and restore Windows and Linux system running on UEFI BIOS.
What is special about EFI System Cloner?
- Small, only 300K in size, EFI System Cloner is small enough to be embedded into UEFI BIOS.
- Nimble, as a EFI software, EFI System Cloner is much faster than the conventional DOS and Windows based system cloning software.
- Simple, copy the files in a USB stick, you are good to go.
- Free, EFI System Cloner is completely free for non-commercial use.
How to use EFI System Cloner
Create a bootable USB: 1. Format a USB stick as FAT32. 2. Copy EFI System Cloner in the USB.
Clone System: 1. Make sure the BIOS is configure to boot UEFI. 2. Boot from the EFI System Cloner USB. 3. Select Backup.
Restore System: 1. Boot from the EFI System Cloner USB. 2. Select Restore.
If you want to use EFI System Cloner in a commercial environment, contact us for license authorization.
