Everything Search Engine
Everything Search Engine to mały, bezpłatny program (także w wersji przenośnej) który pozwala na łatwe i szybkie wyszukiwanie plików i folderów. Program posiada prosty i miły dla oka interfejs użytkownika, jest bardzo prosty w obsłudze oraz zużywa znikome ilości zasobów komputera.
Everything Search Engine 1.4.1.895
9 February 2018: Version 1.4.1.895
added .jpeg extension to the image information search functions.
added support for cluster sizes larger than 64k.
added preview_context ini setting.
updated localization
fixed a crash when clearing search history.
fixed a security issue when running a FTP server.
fixed an issue preventing Everything from closing when pressing ESC
fixed an issue where Everything would lose the current sort after reindexing.
fixed an issue when using invalid characters to rename a file.
fixed a crash when rendering tall or wide images.
fixed an issue when shutting down Everything would cause it to miss changes.
fixed a memory alignment issue.
fixed database corruption when renaming a folder when folder size indexing is enabled or when there is a folder exclude.
fixed an issue with circular NTFS/ReFS folder parents.
7 June 2017: Version 1.4.1.877
added option to index size, dates and attributes
added option to enable fast sorting of size, dates, attributes, path and extension
added thumbnail view
added preview pane
added REFS support
added advanced searching
added multi-file renaming
added content searching
added search history organizer
added show total size in status bar option
added single click open option
added full row select option
added perl compatible regex
added new search functions
added / search commands
added filter functions
added new Everything icon
improved folder deletion performance
improved indexing when using file and folder excludes
improved search term highlighting
improved database blocking
improved indexes updating
improved folder index monitoring
improved NTFS indexing
improved re-indexing performance when the existing indexes are up to date
improved IPC
fixed an issue causing Everything to hang onto a volume handle when trying to safely remove a device
fixed an issue with excludes being ignored when rebuilding the indexes
fixed a crash when renaming a folder that had subfolders that should be excluded
fixed an issue with sorting by date created ascending and date accessed ascending
fixed a crash when accessing file information cache
fixed an issue with ETP url links and special characters
fixed a focus issue with UAC prompts
fixed an issue when opening a file as admin
fixed a lock in the Everything service
fixed an issue with a race condition and initializing COM
fixed a hang when deleting a registry key
fixed an issue with very large sorts
fixed an issue with !parent:, !child: and !c:\path
fixed an issue with filter modifiers
fixed an issue with file:!
fixed an issue with indexing hidden or system folders/files
fixed an issue with previous navigation searches
fixed an issue when searching for a \path\
fixed a crash when cutting an item multiple times
Pobieranie:
