Ghostpress - bezpłatny anty-logger
Ghostpress to mały i bezpłatny program który chroni użytkownika przed keyloggerami, chroni przed przechwytywaniem uderzeń w klawisze przez nieuprawnione aplikacje.
Nawet, jeżeli w systemie mamy keyloggera to i tak taki keylogger nie ukradnie żadnych poprawnych danych ponieważ Ghostpress ukrywa przed nim sekwencje znaków wpisywane za pomocą klawiatury.
Program posiada polską wersję językową. :)
Strona producenta
Ukazała się wersja 0.9
The new update is released. The current changelog:
Version 0.9
+Added warning for critical detections
+3 widget styles: Big widget, small widget and icon only
+Delay protection (harder to identify users by their typing style)
+Indonesian translation
#Possible security risk due invalid protection detection fixed
#Bug fix of the crash after pressing a key within 2,5 seconds after disabling the widget animation
#Render bug when switching to the minimized windows by Alt-Tab switch fixed
#Changed the multi-instance detection without using a listening local socket
#Better Polish translation
#Minor French translation improvements
#Minor UI improvements
A big update is released!
Changelog:
Version 1.0
+White list
+Choice between notify icon and widget
+Option to disable automatic detection (Windows Vista+)
+Close dialogue
+Compatibility mode for all non-supported keyboards with basic protection
+Developer API support
+Croatian translation
+Czech translation (Thanks to LooToS)
+Dutch translation
+Latvian translation (Thanks to Sapn1s/Aigars Veikšins)
#Improved anti typing fingerprinting (delay protection)
#Major rehook protection improvement (Windows Vista+)
#Rare delay protection bug fixed
#System information not visible after start with "-widget" parameter fixed
#Minor performance improvements
#Better and faster 32/64-bit detection
#UAC skipped widget startup
#Enhanced delay protection random generation bug fix
#Missing translation fixed
#Rare close crash fixed
GhostPress v 1.2
Version 1.2
#Minor language and text width improvements
#Rare window switch bug fixed
#Autostart bug fixed
#Removed print screen protection
Ghostpress 1.3.422
1.3
+Portable parameter (settings wont be saved)
+Romanian translation (Thanks to Arthur)
+Portugese translation #Animated widget will go partly transparent when no key was pressed within the last 10 seconds
#Moved update system to new domain with encryption enforced
#Fixed minor update check bug
#Fixed non-administrator bug for adding autostart
#Minor UI changes March 9,
alco
