LED Flashlight (Android) za darmo
alco
m5l-7MQzrg950Uzu7HsJE6RS1X2zukTisRklpbHaXsrAJE3Y2ekxVfEtC3QsLCNe92c=h310-rw
ivFZkfJVtKnZs4eTrEGS9u-dEyts9pZXzKYr3TGLErDCgCbV8cVi9f4fSm9-gFjKx0fQ=h310-rw
LEFKQJAn6Og0JmlLmIfY_0lzcWnBBmhROaW5vSbFd9qyqjrnmvhn1nPjIxBTkr16Dr0=h310-rw
Forget the other flashlight apps.
Because you have the most beautiful and brightest flashlight.
* Brightest LED and screen lights
* Find things hidden in every corner easily with the camera preview function.
* With widget, use flashlight without launching the app
* Easy to access strobe and SOS function
* Simple and Beautiful design
* Designed for all types of devices
To get the premium version from 'App Of The Day', please do the followings:
Touch the menu button on the top-right of the screen → Select "Feedback & Contact" or "Info" or "About" → Select "Enter promo code" → enter code 'appoftheday'
If you can't see "Enter promo code" menu, it means you've already got the premium version.
Tqe8j2Q1uX2qsB0zOpyNxzxWOnU27q7lvQ-00HSXs6Tybq09BdTn5rVmmOL6nOGYNQ=w100
FlashLight Pro za darmo na:
You will surely get advantages from this app as following
*This app do not track your location keep your privacy protected
*This app do not show any kind of ads
*This app do not consume more battery and it result more light for more time
*When ever in dark want to stop any vehicle just push the icon "seek help" and put flashlight towards the vehicle
*It is so easy a 4 year child can also use it even for learning a switch concept "on" and "off"
L-CV5eDES3SEE2VH_ezx6oZqy3ANjpUZx8LGE_8iEjubY40nJbObyoohLiYiuXzQq2yo=h900
tBX8UupRuo2V6iWIlSb763knXpKEMRibsXrHoDLwHhYa_QiC3ilCC-Cc9a6IPsi3Ew=h900
twgzrXBr0jrqbQewzn-T5ygttNxJY-WjbLeCmZEPso4n4S4qi-8KlEK61PoMfjMe2TU=h900
