DziadDalf
Z DziadLandu ;p
cFosSpeed 10.51 build 2358
x Fixed an long-standing bug in RWIN expansion that could lead to slow
connection setups.
x Fixed a display bug in "current connections" which didn't indicate user-changed
prio.
DziadDalf
Z DziadLandu ;p
cFosSpeed 10.51 build 2359
+ When cFosSpeed was transferring lots of data, spd commands and current
connections could sometimes answer very slowly. Fixed.
x Fixed memory leak in driver.
x Fixed UDP connection count.
DziadDalf
Z DziadLandu ;p
cFosSpeed 10.51 build 2360
+ In the advanced current connection dialog, large numbers are now displayed
with separators.
+ Changed HTTP requests so they are hopefully more compatible with certain
proxies.
x Fixed several bugs in dialogs for usage graph and priority settings.
x Fixed "spd cons -cps" speed display.
x Fixed "spd tcb <remote wild>". You can specify a wildcard for the remote
address:port pair. The wildcard is case-insensitive, IPv6 addresses
are in "[]" and IPv6 addresses are written as short as possible (omitting
leading zeros and using the "::" abbreviation.
DziadDalf
Z DziadLandu ;p
cFosSpeed 10.51 build 2362
+ Removed "idle" class. Now every connection with set L7-protocol and known
program name gets a class assigned right away.
- Build 2361 still generates a bogus virus detection by Yandex Safebrowsing. All
other virus checker from virustotal.com return negative results.
DziadDalf
Z DziadLandu ;p
cFosSpeed 10.59 build 2402
x Fixed bug in bulk detection: if downloading with HTTP, bulk streams would be
re-classified as HTTP_C for a short time after each new GET. Fixed.
x Fixed statistics for LSO/RSC packets.
- Removed mtu_limit variable.
cFosSpeed 10.59 build 2401 alpha
x Fixed Bluescreen caused by LSO packet without MSS info. Thanks to Priben
Kranz for crash dump.
cFosSpeed 10.59 build 2400 alpha
* Extensive re-write of the cFosSpeed core networking code:
-- Special speed-up for passthrough LAN traffic (not traffic shaped)
-- Designed to keep all out-of-band packet info intact, resulting in
improved ad hoc VPN compatibility
-- Improved analysis of networking edge cases
-- Support of NDIS header/data split
-- Additional speed improvements of Traffic Shaping path
-- Support for Task Offloading: Checksum Offloading (IP and TCP/UDP), Large
Segment Offloading and Receive Segment Coalescing
With the new networking code cFosSpeed has only barely noticeable CPU load
even at full blast 10 GBit/s LAN traffic!
Alpha version! Please test and report. This version might be unstable, so
don't use it in a production environment.
DziadDalf
Z DziadLandu ;p
cFosSpeed 10.59 build 2404
x Hopefully fixed a crash reported by leozhdan.
- When allocating memory, only nonpaged memory will now be used. No more
allocation and locking of paged memory is performed. This worked only
very rarely anyway.
- Update to Visual Studio 2019.
- Removed variables fixed_speed, data_compression and vj_compression.
DziadDalf
Z DziadLandu ;p
cFosSpeed 10.59 build 2410
+ Speeded reaction time in RWIN expansion thus increasing throughput.
x Fixed a bluescreen when fragmented packets where dumped. Thanks to
a11111135 for crash dump.
x Fixed TCP connection problem on connections without TCP WSCALE if RWIN
expansion was enabled.
x Fixed spd adapter_info -json.
- Dumps will reflect TCP/UDP checksum offloads more correctly.
