DziadDalf
Z DziadLandu ;p
cFosSpeed 10.59 build 2414
x Fixed a condition that could lead to starving TCP connections when RWIN
expansion was used.
x Fixed a crash in spd.exe service, this time for real.
+ Added new "spd gset passthru" modes. So far we had:
0 = switch off passthru mode - data is put through driver.
1 = do as little as possible to hand packets to the next driver.
2 = do all the port handling, but don't analyze or modify packet.
Now we add:
3 = tx data: like 1, rx data: like 2.
4 = tx data: like 2, rx data: like 1.
Debugging purpose only.
- RWIN expansion will now by default negotiate windows that allow full blast
downloads with an RTT of 200 ms. Change expand_rwin_dest_time if you want
a different time.
DziadDalf
Z DziadLandu ;p
cFosSpeed 10.59 build 2416
x Fixed serious bug in WAN mode. Thanks to ckcampbell1963 for memory dump.
x Sometimes the language selected at installation time wasn't used in the
demon. Likewise, a language change in the daemon would not change the
language for the next installation. Fixed.
DziadDalf
Z DziadLandu ;p
cFosSpeed 11.01 build 2430
x (Unsuccessfully) tried to fix an incompatibility with Killer Networking NIC.
Thanks to Mathias Schmitt and BlankFX for bug reports and testing.
x Fixed NDIS func_trace output.
- Added more trace output for key download.
cFosSpeed 11.01 build 2431
x Fixed crash in installer.
x Fixed rare bluescreen. Thanks to gobletfire for kernel dump.
x Hopefully fixed problem with key activation.
- Added proper counting of header errors and unsupported header/data split
points.
- Improved readability of NDIS traces.
Mohammad.Poorya
19 Wrzesień 2018
On a Bike!
cFosSpeed 11.01 Build 2431 Beta
Change in 11.01 Build 2431 Beta:
  • Fixed crash in installer.
  • Fixed rare bluescreen. Thanks to gobletfire for kernel dump.
  • Hopefully fixed problem with key activation.
  • Added proper counting of header errors and unsupported header/data split points.
  • Improved readability of NDIS traces.
Download | Beta -
DziadDalf
Z DziadLandu ;p
cFosSpeed 11.01 build 2432
x Fixed bug in setup where key file is downloaded. This could have been
responsible for connection problems from China.
x Fixed bug in handling of WAN devices. This could have prevented some VPNs
from work.
- Support for May 2020 update of Windows 10, version 2004, codename 20H1.
DziadDalf
Z DziadLandu ;p
cFosSpeed 11.01 build 2434
+ Much better dumping of packets when task offloading is active.
x Fixed issues in RWIN expansion and DNS TTL patching where checksums were
corrupted. Thanks to all the tests and traces I got from Contor, kasiusz.j,
robert korneluk, Vladimir Varbanov, BlankFX and Mathias Schmitt.
DziadDalf
Z DziadLandu ;p
cFosSpeed 11.01 build 2435
+ cFosSpeed will now disconnect (and reset all stats, etc.) when your WiFi
looses connection or when you pull the Ethernet plug.
x Fixed sending net_talk packets. Was broken in v11.0.
x Fixed bug in NDIS packet handling. Hopefully, this fixes problems with the
Killer network card.
x If a second monitor was used to the right of your main monitor, cFosSpeed
could have erroneously closed the window for a fullscreen window on
monitor 2. Fixed.
Mohammad.Poorya
19 Wrzesień 2018
On a Bike!
cFosSpeed 11.03 build 2438 beta
+ The Adapter Info no longer include adapters that have neither had any
traffic nor are purely virtual adapters anyway.
x Sometimes the HTML dialog files are not properly generated resulting in
empty dialogs. While the problem is not yet fixed, the next start of
cFosSpeed will at least detect that and generate proper dialogs.
- Improved readability of items in Adapter Info dialog.
