DziadDalf
Z DziadLandu ;p
cFosSpeed 11.11 build 2504
* Finally, due to public demand: Added port prioritization to preferences UI.
You can specify local and remote ports (both TCP and UDP ports will be
matched), either individual ports, a range, or a combination of both.
E.g. "80,443,1000:1010" will match ports 80 and 443, and ports 1000-1010.
See below for the new filter expression.
Mohammad.Poorya
19 Wrzesień 2018
On a Bike!
cFosSpeed 11.11 Build 2508 Beta
cFosSpeed 11.11 build 2508
x Newly added programs were always added with "normal" priority. Fixed.
Thanks to Michael H.
x When changing monitor resolution, cFosSpeed will move now its status window
to a formerly saved position or the default position. Thanks to John E. G.
for bug report.
Download:
Mohammad.Poorya
19 Wrzesień 2018
On a Bike!
cFosSpeed 11.11 Build 2510 Beta
cFosSpeed 11.11 build 2510
- Spd commands "addkey" and "showsect" are available again.
- Meta dumps now also include the space method by which traffic is counted.
For more info, see collected-data.txt.
x Fixed a very slow handle leak.
Download:
DziadDalf
Z DziadLandu ;p
cFosSpeed 12.01 build 2514
+ The "Adapter Info" UI now displays WiFi frequency usage graphs for the
2.4 GHz, 5 GHz and 6+ GHz bands. This can help you optimize the used WiFi
channels for optimal performance.
DziadDalf
Z DziadLandu ;p
cFosSpeed 12.01 build 2519
+ The built-in UI HTTP server now prefers its own mime types. This prevents
UI loading problems if Windows mime types have the wrong values.
x Fixed a bug where "Expires" HTTP header was sometimes garbled.
- Old .HTA functionality that was removed in cFosSpeed 10.20 is available
again.
DziadDalf
Z DziadLandu ;p
cFosSpeed 12.01 build 2523
* New! The cFosSpeed Game Analyzer: When you are gaming there are often
situations where both your Internet connection and your computer performance
is very important. So if you are in a big fight and experience problems,
the Game Analyzer can help you diagnose bottlenecks in speed, latency, CPU,
GPU, and memory performance. Click on "Game Analayzer" in the cFosSpeed
context menu to open it. For more information, see
