DziadDalf
Z DziadLandu ;p
cFosSpeed 11.05 build 2456
+ Improved throughput with 2.5GE or faster network cards.
+ Added passthru mode 6, which causes the whole NET_BUFFER_LIST chain to be
ignored.
x Some users experienced mouse hangs while downloading heavily. Now the
number of worker threads has been limited to half the number of CPU cores to
fix this.
DziadDalf
Z DziadLandu ;p
cFosSpeed 11.05 build 2457
x Fixed a bluescreen in the 32-bit version.
x cFosSpeed accessed RSC structures on NDIS < 6.30, where such structures are
not supported. This led to all kinds of statistical miscalculations. Fixed.
x Fixed wrong average transfer units (cons -atu). This is used in rx shaping
as well.
x Fixed "spd perf" headings.
Mohammad.Poorya
19 Wrzesień 2018
On a Bike!
Mohammad.Poorya
19 Wrzesień 2018
On a Bike!
cFosSpeed 11.07 Build 2470 Beta
Change in 11.07 Build 2470 Beta:
  • Set copy_oob = 0. This should fix a long-standing bug (since 10.59). Thanks to Michael B and Andreas B for testing.
  • Added gset oob_bits for testing.
  • Enabled more agressive memory debugging.
Download | Beta -
DziadDalf
Z DziadLandu ;p
cFosSpeed 11.09 build 2482
x Fixed broken skin menus. This bug was introduced in build 11.09.2480.
x Fixed type/code versions of -icmp-type and -icmp-typev6. This bug was
- Added more games to settings.ini.
DziadDalf
Z DziadLandu ;p
cFosSpeed 11.11 build 2490
x Fix for ProtonVPN and Speedify VPN (and maybe other VPN services as well):
the window for the VPN connection is now displayed correctly. Thanks to
Dima S. for bug report.
x Burst code could have selected an unusable pinger. Fixed.
x Removed WebView2 files for now.
x Fixed a rare, ancient crash when unloading.
DziadDalf
Z DziadLandu ;p
cFosSpeed 11.11 build 2500
* Much improved dialogs!
We completely reworked the cFos Speed configuration dialogs. They now use a
comprehensive HTTP API (see
and Vue.js and Bootstrap and are thus responsive and easier to maintain.
We hope you enjoy the new design! :)
In addition, cFosSpeed can now use Chromium Webview2 to display its dialogs.
This means that the new dialogs are displayed in our own window, instead of
the default web browser window. This allows for improved visual experience
and pre-loading of the HTML / Javascript code.
+ Added "spd gset worker_threads" setting, default is 0, which means using
half the number of cores. Any number between 1 and the actual number of
cores can be set. You MUST use "spd gset worker_threads XXX -save" and
restart cFosSpeed, since the number is only used on driver start.
This selects the number of threads used for data transfer. Higher numbers
might improve thruput, but might also lead to short freezes.
