helium
16 Czerwiec 2010
EZ CD Audio Converter 4.0.4 (9 May 2016)
Fixed a bug in showing the CD-Text Album Artist and Album metadata in Audio CD Ripper
Changed the default character set of Cue Sheet and M3U playlist to Ansi/ISO-8859-1 for better compatibility with other apps (that don't properly support the Unicode variants)
Turkish, Catalan, and Spanish language updates
EZ CD Audio Converter Free
EZ CD Audio Converter Ultimate
helium
16 Czerwiec 2010
EZ CD Audio Converter 4.0.5 (24 May 2016)
Fixed the bug in reading ID3V2 Unicode COMM tag set by a 3rd party app (Unicode BOM in empty description field problem)
Fixed a possible memory access violation when creating an ISO image from a data disc
French language update
helium
16 Czerwiec 2010
EZ CD Audio Converter 4.0.6.1 (16 August 2016)
Certified for Windows 10 Anniversary edition
Improved the Windows Explorer view of the main user interface
Opus codec 1.1.3
Now keeps the original FLAC encoder vendor string when updating metadata of existing FLAC files
General performance improvements
Language updates: Spanish, French
helium
16 Czerwiec 2010
EZ CD Audio Converter 4.0.8.1 (18 August 2016)
Fixed startup errors (path not found in Win7/8 or can’t find path shell in Win10)
Fixed DPI scaling in 4k mode (200% DPI scaling)
EZ CD Audio Converter 4.1.0.1
Improved user interace DPI scaling, perfect scaling with all Windows DPI settings
4k
Windows large fonts
All Windows DPI scale values (100%-400%)
Full pixel resolution for cover art and embedded metadata images (like before)
helium
16 Czerwiec 2010
EZ CD Audio Converter 5.0 (20th Anniversary Edition)
Support for high-resolution displays (4k, large fonts, Windows DPI scaling)
Improved user interface
Latest and best audio codecs are included
helium
16 Czerwiec 2010
EZ CD Audio Converter 5.0.2 (26 October 2016)
Fixed the problem that caused startup failure on some computers showing "System can't find the path specified" error message
helium
16 Czerwiec 2010
EZ CD Audio Converter 5.0.3 (08 November 2016)
Improved memory footprint and memory performance
Fixed a major memory leak in MP3 encoder
Fixed memory leaks in FLAC encoder and FLAC metadata read/write
Fixed other minor memory leaks
Improved encode/decode performance by utilizing the SSE3, SSE4, AVX, and AVX2 special processor instructions (previously SSE and SSE2 only)
helium
16 Czerwiec 2010
EZ CD Audio Converter 5.0.4 (09 December 2016)
Implemented exclusive ripping and burning mode that prevents interference from other apps
Improved user interface performance, can be seen as enhanced performance in ripping and audio file conversion
Fixed a bug in WMA decoder of previous update (conversion from WMA format possibly failed)
EZ CD Audio Converter 5.0.5
Amazon Cover Art search works again (protocol change)
Improved multi-channel to stereo mixing matrix, removed auto-gain to prevent clipping, gain can be manually adjusted with the ReplayGain
helium
16 Czerwiec 2010
