FBackup 9.0 Build 199
March 19, 2021
  • Added: Old catalogs are renamed and kept when importing jobs from previous versions
  • Added: Summary is saved to log file for easier troubleshooting
  • Fixed: Previous executions were deleted when create full paths was disabled for imported jobs
  • Fixed: Cannot create folder error (the parameter is incorrect)
Mohammad.Poorya
19 Wrzesień 2018
On a Bike!
FBackup 9.0.258
Changes in FBackup 9.0.258 (05-May-2021)
  • Fixed: Large fonts display
  • Fixed: AV when running a backup on two plugins
  • Fixed: Some Google Drive sources are not considered
  • Fixed: Filters are not saved correctly
  • Fixed: Warning on test for backups to Google Drive
Download:
FBackup 9.0.266
Changes in FBackup 9.0.266 (10-May-2021)
  • Fixed: Block backup from Dropbox returned a zip error
  • Fixed: Files were backed up every time in certain situations
  • Fixed: Error with backup history reporting
  • Fixed: Some extra mirror logging
  • Fixed: Log import error
Changes in FBackup 9.0.261 (05-May-2021)
  • Fixed: Import from old versions (i.e. v5) showed no history
  • Fixed: Appcrash fix when using different source types
FBackup 9.0 Build 290
Changes in FBackup 9.0.290 (25-May-2021)
  • Updated: Better plugin management when opening backups
  • Fixed: Warnings on backups that used obfuscation in certain situations
  • Fixed: Files not found when testing backup jobs for Microsoft Outlook in some situations
Changes in FBackup 9.0.287 (21-May-2021)
  • Fixed: Importing jobs with unavailable plugins failed in certain situations
  • Fixed: Could not apply catalog patch error on backup jobs for some Firefox versions
Mohammad.Poorya
19 Wrzesień 2018
On a Bike!
FBackup 9.0.297
Changes in FBackup 9.0.297 (27-May-2021)
  • Fixed: Use only archiving bit did not work correctly all the time
  • Fixed: Invalid backup error for full backups on large files in some situations
  • Fixed: Overriding filters were not working correctly for some particular jobs
  • Fixed: Catalogs were not included when using the FBackup plugin in some situations
  • Fixed: Testing backup jobs using the FBackup plugin erroneously showed missing config files
Download:
FBackup 9.1 Build 357
July 8, 2021
  • Added: Warning notices with extra details for backup plugins
  • Updated: Improved job import from previous versions
  • Updated: Korean translation
  • Fixed: Selecting a customized filter in rare situations returned an error
  • Fixed: Folder filters when using non windows sources
  • Fixed: Test and restore not working for imported v8 backups using IE favorites plugin
  • Fixed: Invalid strings in some languages
  • Fixed: Mirror VSS problems (backup was frozen in some rare situations)
FBackup 9.1 Build 369
July 14, 2021
  • Updated: Romanian translation
  • Fixed: Source folders were duplicated in rare situations for mirror backups
  • Fixed: Crash when loading a backup job using a locked predefined destination
  • Fixed: Restoring a backup using Google Chrome plugin on a different machine had errors
FBackup 9.3 Build 420
October 11, 2021
  • Added: Full compatibility with Windows 11
  • Updated: Improved memory usage when backing up more than 1.5 million files
  • Updated: Improved backup speed for backup types that use compression
  • Updated: Improved test speed (faster CRC calculations)
  • Fixed: Cannot delete folder warnings for mirror backups using encryption and obfuscation
