Adlice Diag (Anti-malware Diagnostic)
Adlice Diag 4.0.8.0​
  • Report window refinements:
  • Overview and sidebar polish, including UCheck (outdated software) adjustments
  • Fixed a layout overlap in the license / account area
  • Fixed mocked data leftover
  • Report now falls back to the current Windows user when the stored scan user is empty, so the "User" field is no longer blank
  • Updated to core 9.0.10
Adlice Diag 4.0.9.0​
  • Report window, Processes section: restored the full column set and added detail:
  • Path and Command columns are back, plus a new Target column that shows the real payload a process was redirected to (for svchost, the hosted service DLL)
  • Restored columns that were missing across the other sections (Modules, Registry, Tasks, Services, WMI, Web, Hosts, Antirootkit, Filesystem) so the report matches the classic view again — Pid, Status, Path, Data and Cloud where applicable
  • Scan results now show the hosted service DLL next to a svchost process's command line
  • Fixed detection of installed software backed by winget (Visual C++ redistributables,
  • .NET runtimes, and others): a slow-to-start helper could return no output, causing those
  • programs to be listed as unsupported even though they were present
  • Updated to core 9.0.11:
  • svchost analysis reworked to further cut false positives: instead of judging the svchost host itself, the hosted service DLL is now resolved and scanned directly with the regular signatures, and shown as the detection target
Adlice Diag 4.1.0.0​
  • New scan results page:
  • A single list of everything found, with the threat, object type and location side by
  • side, plus an expandable detail panel per item (size, signature, hash, VirusTotal
  • score and a link, and extra details specific to each object type)
  • Threat severity is shown as a coloured badge, and unsigned files are flagged
  • Files in commonly abused locations are highlighted
  • Checking an item in a category tab adds it to the list; unchecking there removes it,
  • while unchecking in the results list simply clears it for quarantine
  • Drag anywhere on a row to scroll the list sideways when columns are cramped
  • Quarantine now stays on the results page and updates each line as it goes, with a
  • progress bar, the item being processed, and a Stop button
  • Fixed quarantine removing items that were not selected
  • Each line now shows what happened to it — Removed, or Not processed for items left
  • unchecked — instead of staying on "Found"
  • When it finishes, the page offers Finish and retires the checkboxes; a new scan
  • resets it
  • Removal reports now describe the removal instead of the scan they followed:
  • The headline count, the history list and the category tiles report what was actually
  • removed (a removal that quarantined one item no longer reports the whole scan)
  • A single Removal section lists every processed item; the scan-only sections, which
  • were always empty, are hidden
  • New Customize-scan page: themed rules and locations trees, a draggable splitter between
  • them, a Quick / Custom switch, and Reset / import / download-signatures actions
  • Fixed the process tree showing a flat list instead of the real parent/child hierarchy
  • when the outdated-software check was enabled
  • Fixed a crash when starting a quarantine from the results page
  • Bulk check / uncheck in the results list is now immediate instead of taking a second,
  • and shows progress while it rebuilds
  • Installer: added a licence acceptance page; the uninstaller now removes a temporary
  • file it used to leave behind, and unattended uninstalls no longer stop on a prompt
  • The modern interface now requires Windows 10 version 1709 or later; older systems
  • install the classic interface automatically (fixes a startup failure on Windows Server
  • and early Windows 10)
  • Updated to core 9.0.12, still labeled 9.0.11 (bundles RKSdk + utility / UI layers):
  • Yolnir anti-rootkit driver updated to 3.5.0, with Microsoft-attestation-signed
  • builds for 64-bit, 32-bit and ARM64 systems
  • Fixed the process tree being reported before it was built, which left consumers
  • with an empty hierarchy
  • Fixed a shared iterator in the process tree that could corrupt a walk, or crash,
  • when the tree was traversed recursively or from two places at once
  • Fixed a program launch being treated as finished when its first output was slow
  • Pending log entries are now flushed when the application shuts down
Adlice Diag 4.1.1.0​
  • Scan results are back to two steps, as they were before:
  • The scan ends on the category tabs, where detections are selected; the "Removal" button then opens the list of what you picked, where quarantine happens
  • Categories are shown as tabs across the top, with their name, count and a red badge when a category holds something malicious — they scroll when the window is too narrow
  • Results open on the first category holding something malicious, or failing that the first with any detection, instead of an empty tab
  • Each category has a checkbox beside its title to select or clear all of it
  • Going back from the removal list returns to the tab you were on
  • Unchecking an item on the removal list no longer removes it from the list, it just unchecks it
  • The removal list has its own search box (name, threat, location or type)
  • Scrolling a long list of detections is no longer slow
  • Progress is now shown while results load, while a large list is being prepared, and while selecting or clearing a whole category
  • Removed the "unusual location" note from the detection details: it flagged ordinary software installed per-user, so the detection level alone now speaks
  • Fixed the Outdated Software category showing no count, and being skipped when clearing the whole selection
  • Core version label updated to 9.0.12; the engine changes it covers shipped with the previous release
Adlice Diag 4.2.0.0​
V4.2.0 11/06/2026
- New Disk Usage tool, for seeing where the space actually went:
* A view of every drive, with a treemap beside the tree so the big items are findable at a glance
* Sizes shown both on-disk and nominal, so compressed and sparse files are not silently misreported
* Breakdown by file type, and a list of the largest objects; clicking one jumps to it in the tree
* Filter by name or extension, and narrow to items over 100 MB or unused for more than a year
* Right-click to open, explore, copy a path, or delete — to the Recycle Bin or permanently
* Export the view to CSV
- Disk Cleanup rebuilt on the same engine, and far more careful about what it offers:
* Only locations verified as safe are scanned at all. Anything holding passwords, cookies, bookmarks, browsing sessions or saved form data is never listed, never selected and never deleted
* Backup files (.bak, .old) are no longer treated as disposable — several catalog entries use them for save games and project backups
* Nothing is offered from your Documents, Desktop, Music, Pictures or Videos folders on a filename pattern alone
* Each category now carries its own icon, so browsers, logs, caches and crash reports are distinguishable in a long list
* Cleaning deletes in place: the view updates without a full rescan, and the folders you had open stay open
- Fast and full scan scopes: the fast scan runs at startup and feeds the dashboard, with the full catalog scan available on demand
- Progress now tracks the work rather than the bytes, so the bar no longer races to halfway on large files and then crawls
- Quarantine handles a large store properly:
* A quarantine written before folder grouping is reorganised automatically rather than showing thousands of loose entries
* The 1000-row limit is gone — recovering from a mass false positive no longer leaves "Empty quarantine" as the only available action
- Expired licenses now open My Account, where the key and renewal are, instead of the activation flow meant for new purchases
- Exclusions added from the scan results now appear immediately in Settings
- Report windows open centred on the main window and are clamped to the screen, so a report is no longer clipped at high display scaling
- Added Norwegian (thanks to Christer Johansen); German reviewed and corrected throughout
- The sidebar expands on hover when collapsed, without pushing the page
