Advanced Uninstaller PRO 11.27
Added the virus check function to Daily Health Check; from now on Daily Helath Check will be able to detect viruses that added themselves to your Windows startup. It will also continuously monitor your PC, display a brief report when something comes up and allow you to perform all necessary maintenance tasks through one “Fix all” button!
Advanced Uninstaller PRO 11.28
Advanced Uninstaller PRO 11.31
We just added the virus check function to Daily Health Check; from now on Daily Helath Check will be able to detect viruses that added themselves to your Windows startup. It will also continuously monitor your PC, display a brief report when something comes up and allow you to perform all necessary maintenance tasks through one “Fix all” button! Enjoy!
P.S. There is an easy way of Daily Health Check – in case you don’t want to start it with Windows:
double click Daily Health Check’s system tray icon
in the upper right corner click on “settings”
look for “Enable Daily Health Check” then uncheck this option
Advanced Uninstaller PRO 11.32
We just added the “Windows Log Files” and “Windows Error Reporting” cleaners and enabled them in your Daily Health Check. You can find them at the bottom of the “Health issues” tab. Enjoy!
Advanced Uninstaller PRO 11.35
We just improved the cleaning procedure! Version 11.35 features an improved cleaning algorithm. The “Garbage files” cleaner will now scan for even more temporary files at a higher speed.
Advanced Uninstaller PRO 11.36
We have added and activated the “Recycle Bin” and “Application Leftovers” cleaners for you. Daily Health Check can now perform a deep scan to detect garbage files within each application’s folder.
Advanced Uninstaller PRO 11.37
In version 11.37 we improved both the Old Restore Points and the Google Chrome Temporary Files cleaning procedures. After cleaning the Google Chrome garbage files we’ll restore all your open browsing sessions!
Advanced Uninstaller PRO 11.40
In version 11.40 we improved cleaning of old restore points! Recovering of the disk space used by older restore points is now much faster and works perfectly on all Windows versions. More than this, we added the Swedish language translation.
Advanced Uninstaller PRO 11.42
This new release features an improved cleaning algorithm. The “Garbage files” cleaner will now scan for even more temporary files at a higher speed. You’ll notice it in tomorrow’s scan! :)
