Herran
8 Listopad 2017
Like every year AOMEI is holding a giveaway event to celebrate the Halloween this year too. This year they are giving away full version of AOMEI Backupper Pro. It is a really useful software that can be used to keep regular backups of your important files, clone a system or to migrate from one hard drive to another.
AOMEI Backupper Professional provides some of the standard features along with some special tools that are not found in other backup software:
  • Backup your files: It can be used to create and keep regular backups of your files and folders. It supports incremental and differential backups. In addition to files or folder backups, it can backup entire partitions and entire hard drives.
  • Many ways to restore files: It allows you to restore files in complete restore mode or selective files mode. You can extract individual files from the backup too. It can also restore full partition backups to different size partitions or hard drives using the dissimilar hardware restore feature.
In order to claim the AOMEI Backupper Pro license, you can visit the special link
and download the ZIP archive. Inside the ZIP archive, you will find the setup installer package for AOMEI Backupper Pro and the license code. You can register Backupper Pro using this license code between October 25, 2019 and November 1, 2019.
Aomei Backupper Professional
Link skasowałem, wstawiłeś info które było podane 9 maja
ten sam klucz, ten sam link, nawet w komentarzach na tamtej stronie napisane jest:
Tretan May 15, 2019 at 5:18 pm
The giveaway has expired on 11th May. The license code is no longer valid for activation.
Pisałem żebyś sprawdzał zanim dodasz, to że jakaś strona ( w tym przypadku buz99 ) dodaje jakieś info nie znaczy że jest prawidłowe.Nie wiem, piszą żeby tylko naklepać odwiedzin i nie sprawdzają.
A nie przyszło ci przypadkiem do głowy żeby zobaczyc datę wystawienia postu na stronie do której był link?
Updated on December 31, 2019
A nie przyszło ci przypadkiem do głowy żeby zobaczyc datę na stronie do której był link?
Oczywiście że przyszło i sprawdziłem :ok to jest ten sam klucz to raz a dwa nie aktywujesz go, sprawdź sobie.
