Auto Screen Capture 2.4.1.9​
Screenshots count is reset when screenshots limit is reached to avoid falling into an infinite loop. New trigger actions Restart Screen Capture, Delete Screenshots By Cycle Count, and Delete Screenshots From Oldest Capture Cycle. New command "-restart". New macro tag "%capturenow%". Screenshots that fail to upload to an SFTP server will try to upload to the same SFTP server in the next capture cycle until the upload is successful.
Auto Screen Capture 2.4.2.3​
  • New trigger conditions CaptureCycleElapsed, DurationFromStartScreenCapture, and DurationFromStopScreenCapture
  • Trigger condition BeforeScreenshotTaken moved to SaveScreenshot method (instead of TakeScreenshot method)
  • Fixed exception errors when opening forms that are already open from system tray icon menu
Auto Screen Capture 2.5.0.9​
  • Fixed modules panel open state so it no longer affects width of tabs view if modules panel's state is open during LoadSettings
  • New schedules no longer crash when using "independent" logic and being started manually from Add Schedule dialog form
  • Schedule scope defaults to "All Screens and Regions" if value of "scope" is empty during loading of schedules collection from XML data file. Removed check on Seconds for schedules during schedule check timer so we can handle schedules when a second is skipped. Added more debug logging statements. Errors and Logs folders now save to AppData\Local instead of base directory if not found
  • Fix to filepaths that may contain whitespace in between sub-folders due to stripping of invalid Windows characters from titles and/or labels before saving the screenshot image file to disk. This should prevent some GDI+ errors when saving JPEGs
  • Fix to schedules not starting or running the next day
  • Startup log file is now written to user's Local AppData directory inside "Auto Screen Capture" directory instead of same directory as application
  • Fixed issue with SFTP settings when FileTransferIsLinuxServer setting was not available in sftp.xml due to an upgrade from an old version of the application
  • Added Preview, Start Screen Capture, and Stop Screen Capture buttons to Dashboard
  • Dynamic Regex Validator and Encryptor/Decryptor tool windows no longer "float"; they now behave like normal non-floating windows
  • Fixed startup issue when upgrading from an old version of the application and using the wrong version of the config file
  • Fixed bug if you opened the application without having Dashboard as your selected tab view on startup
Auto Screen Capture 2.5.1.2​
Restored the ability to use milliseconds for the screen capture interval. Fixed bug with schedules that were supposed to override the main interval so that they now actually do override the main interval. Fixed cosmetic issue with Preview button. Fixed cosmetic issue with Screen Capture Status when Optimize Screen Capture was enabled. Command Deck now shows percentage of tolerance when Optimize Screen Capture is enabled.
