Autorun Organizer 6.0​
Jan 21, 2025
  • When selecting a custom display mode for startup applications (using the Custom button on the top panel), the selected application types are no longer reset when switching to other display modes.
  • The Undo Changes Center window (for restoring backups) has been updated.
  • The product no longer uses VBScript scripts due to Microsoft's plans to phase out its use in Windows.
  • Bug fixed: The search field slightly shifted after the program window was displayed.
Autorun Organizer 7.01​
v. 7.01 03.09.2026​
  • Restored the list sorting feature that became unavailable in the previous version due to the interface uupdate.
  • Fixed a bug where context menu commands for deleting and delaying an application did not work when right-clicking on an unselected entry.
Autorun Organizer v8.0
v. 8.0 19.11.2026​
  • Full High-DPI support. All interface elements are displayed correctly when the system font scaling is set to 125% or higher.
  • Modern High-DPI-aware dark theme.
  • Menu items, buttons, and links now use sentence case instead of title case - for example, "Copy to clipboard" instead of "Copy to Clipboard". This follows current Microsoft recommendations for software interfaces.
  • The installer now adapts to the system UI theme, light or dark. Previously, it only supported the light theme.
  • Bugs fixed:
    1. In the dark theme, the window resize grip in the bottom-right corner of the main window was not displayed.
    2. Settings window: Fixed an intermittent issue where the program restart notification text was incorrectly positioned relative to the button.
    3. Dark theme: Fixed the appearance of white dots on the borders of the bottom panels in program windows.
    4. Optimization recommendations text on the bottom panel could be truncated.
    5. Startup entries with forward slashes in their paths, such as C:/Program Files (x86)/Ubisoft/Ubisoft Game Launcher/upc.exe, are now processed correctly.
