AVI Toolbox – to prosty w obsłudze program umożliwiający wykonanie takich czynności jak cięcie filmu na fragmenty, wyciągnięcie ścieżki dźwiękowej czy zrobienie zrzutu ekranu z filmu. Efekty można zapisać w oddzielnych plikach.
AVI Toolbox is a user-friendly toolbox for common video files operations such as video splitting, audio extraction, and picture capture. Translation for 10+ languages natively supported by AVI Toolbox, making all common video operations a game.
The program has a user friendly interface that allows you to find a certain frame that you w3ant to capture. The precise navigation also allows you to select the correct time at which to trim the video.
AVI toolbox is available in many languages which include English, Arabic, Chinese, Dutch, Finnish, French, German, polish, Russian, Spanish etc. to make it easy for the non English speaking users to take benefit from it. Interface is simple with very few options for interaction. AVI toolbox supports only AVI files for operation.
AVIToolbox features ...
User friendly interface
Extracts parts of vide files
Extracts soundtracks
Pictures capture
Ability to burn / convert DVDs (requires CopyToDVD and ConvertXToDVD)
International support
And much more !
andyxa
29 Grudnia 2011
