BufferZone Pro - wersje stabilne
BufferZone Pro 4.01
Version 4.01
This is a minor version which includes few bug fixes and minor enhanements.
Network Access Control (BufferZone Firewall)
Improved compatibility with commercial Firewalls
Added the option to enable or disable the Firewall
SE7EN
Obejście zabezpieczeń wersji 4.01 :klawik.
SE7EN
Na 64 bit nie sprawdzałem bo nie mam takiego systemu na wirtualu, a i ten trojan "jest zrobiony pod" systemy 32 bitowe.
buto
20 Listopad 2010
No to super , wersja 3 też była dziurawa , nie ma to jak sandboxie tam piaskownica szczelna ,chociaż kto wie.
BufferZone Pro 4.02 127
Confidential Files Exclusion
It is now possible to define files and folders to be exluded from Confidential files defintion, while they reside under a confidential folder.
Bug Fixes (partial list)
Several rare situations which might result in an Operating System instability
Snaptshot restore sometimes failed
Error message when accessing CD/DVD which does not contain a media
BufferZone overlay icons were sometimes not shown correctly
BufferZone Pro 4.04-185
November 7th, 2012 - What's new:
Enhanced Safe URL browser control
It is now possible to control the way Internet Explorer behaves after a zone switch
Improved performance and compatibility with Internet Explorer
If the home page or URL link are on the list of Safe URLs -- Internet Explorer will try to open automatically outside of BufferZone
Prevent BufferZone Services from being stopped
It is now possible to prevent unauthorized users from stopping BufferZone services
Occasional hang of Windows Media player on Windows XP when running inside BufferZone
Improved compatibility with Flash and FireFox running inside BufferZone
Improved compatibility with Symantec Endpoint Security
Improved compatibility with McAfee SaaS and McAfee Total Protection
Occasional removal of "Send to mail recipient" option from the right-click menu
Improved performance when copying large number of files from network drives
Red border was not always shown when using Windows Aero
Open folder for downloaded file on Internet Explorer did not always show the new folder
