Clear Disk Info 3.3.0.0​
Version 3.3 (released in August 17 2022)
  • Added a menu option: Don't show bad status for this disk - Enable this option to prevent the selected disk from be marked with the Warning or the Failing status, regardless of what the S.M.A.R.T. attributes's values are. You can disable this feature again anytime later. This is a per-disk feature.
  • The menu can now be displayed by right clicking an itme in one of the lists.
  • Applied a wider internal threshold to some of the attributes.
Clear Disk Info 4.0.0.0​
Version 4.0 (released in November 10 2022)
  • Added disk monitoring support. When this new feature is enabled, Clear Disk Info whatches the disks you select for monitoring, and reports important changes to the users.
  • Bug fixes
Clear Disk Info 4.4.0.0​
Version 4.4 (released in May 1 2025)
  • Fixed: Clear disk info was not being able to get S.M.A.R.T data on SATA disks plugged in through USB adapters.
  • Fixed: SSD lifetime left was not showing the correct value.
  • Bug fixes
