alco
Build: 3.7.2.658:
- Fixed bugs
- Added improvements
- Improved the hardware detection
- Added feature to delete installer
- Added feature to install updates silently
- Added choose updates download path feature
- Added switches
- Added choose updates install path feature
Instalka 32bit:
Instalka 64bit:
CobraTek PC Info 3.7.8.127
November 9, 2020
  • We are releasing PC Info build 3.7.8.127! It is the major PC Info release. It brings a lot of improvements, changes and bug fixes. You can get this build by using the built-in update feature, ALI or downloading a regular installer from the website.
  • In this build, we improved the hardware detection, fixed an issue with the log in feature when network is disabled or offline. Also, we fixed screen resolution issue. Now, it will display the proper screen resolution if it is bigger than 1920x1080. The localization issues has been fixed as well.
  • We recommend all users to update to this build to get the latest enhancements and bug fixes. Feel free to report any issue to us. We are still working on PC Info Pro features. More news about PC Info Pro will be available later this week.
32bit:
64bit:
CobraTek PC Info 4.0.0.218
Hello!
We are releasing PC Info Pro build 4.0.5.654! It brings the enhancements and bug fixes.
We improved the Network Monitor useful tool. Also, we updated the Nvidia CUDA API to 11.7.1 version in this build. We recommend all PC Info Pro customers to update to this build to have the latest improvements. You can download a regular installer from
, use
or switch to Release channel and use the built-in update feature.
32bit:
64bit:
