Display Driver Uninstaller 15.7.0.1
Display Driver Uninstaller (DDU) V15.7.0.1 Released.
Added support for AMD Crimson driver suite.
Some small fixes
Removed a recently added nVidia Optimus registry entry.
Remove a small leftover from AMD Crimson.
Display Driver Uninstaller (DDU) 15.7.0.2
Display Driver Uninstaller (DDU) V15.7.0.2 Released.
-Added the option to remove the AMD Crimson Shader Cache folder. (Default: Disabled)
-It is now possible to translate the option to remove Geforce Experience (GFE)
-Misc fixes from error spotted on DDU log of some users.
Display Driver Uninstaller (DDU) 15.7.1.0
Display Driver Uninstaller (DDU) V15.7.1.0 Released.
-Added support for Geforce Experience Beta v2.8.0.80 removal
-Some extra nVidia cleanUP additions.
-Japanese translation updated
-German translation updated
Display Driver Uninstaller (DDU) 15.7.2.0
nVidia cleanUP update -Added a better logic on how/when the computer reboot after DDU finished cleaning. -Fixed a bug that prevented the removal of the Geforce Experience "Interface" registry section. Translation Updates : -Korean -Serbian -Spanish
Display Driver Uninstaller 15.7.2.1
More Geforce Experience leftover removal (GRID / LEDVisualizer)
Do not remove the "NVIDIA Virtual Audio Device (Wave Extensible) (WDM) when the "Remove GFE" CheckBox is not ticked
AMD Fuel and GLCache leftovers
Remove invalid or corrupted oemXX.inf (Should help a few users with driver installation failure)
Compiler stuff (Option strict ON) Thanks for Shady7557 for taking the time to convert the code.
Rewrote the SystemRestore section to be compatible with Option Strict (On).
Display Driver Uninstaller 15.7.2.2
Remove an AMD ACP leftover folder.{920DEC42-4CA5-4d1d-9487-67BE645CDDFC}
Some system restore enhancement on the error / catch
Do not Freeze the GUI when doing the System Restore point.
Enable the buttons only when the "rescan" is done (when applicable)
Translation update:
Turkish (Murat 5038)
Display Driver Uninstaller 15.7.3.0
-Fixed the AMP ACP folder removal from latest release.
-Additional AMD removal (SteadyVideo related stuff)
-Additional Registry cleanUP for AMD. (This fixed the Cat 15.12+ asking to update instead of fresh install for some users)
-Fixed a "CMD" pop-up error (0xc0000142) when DDU is restarting the computer in SafeMode.
-General code fixes/enhancements
alco
Display Driver Uninstaller (DDU) V15.7.3.1 Released.
-Fixed the "AMD Settings" issue that some users were reporting. (HUGE Thanks to "Watcher" for testing and feeding me with feedback)
-Additional AMD SteadyVideo removal (Fix SteadyVideo installation error)
-Bug fixes
Display Driver Uninstaller 15.7.4.0
Fix the AMD Steady Video installation error.
Added the rebuild of the performance counter cache within DDU
Additional nVidia CleanUP
Updated Turkish Folder name
Added a 1 time message to ask users to Download DDU from its homepage to encourage the developers to continue to develop DDU. By downloading it from others websites, it cut some revenues that could be useful to DDU. In the event there is a problem with DDU main page, please use Guru3d mirror
Display Driver Uninstaller 15.7.5.1
Display Driver Uninstaller (DDU) V15.7.5.1 Released.
-AMD Vulkan driver files removal. (this will not remove the Vulkan Runtime) -Changed starting Messagebox to Form, works like a splash screen. (Thanks to usermltk) -Added option reboot to Safe Mode with Networking on above mentioned form. (Thanks to usermltk) -Network check before requesting version. Not waiting timeout from requesting version if no networks available. (eg. Safe Mode) (Thanks to usermltk) Known Issues: -There may be an error message about a missing file on startup for the first time. -The new form on startup is not translatable yet.
Display Driver Uninstaller 15.7.5.2
Display Driver Uninstaller (DDU) V15.7.5.2 Released.
-15.7.5.2 Fixed an issue that could prevent the computer to reboot back into Normal mode.
Display Driver Uninstaller (DDU) 15.7.5.3
Display Driver Uninstaller (DDU) V15.7.5.3 Released.
-Fixed GPU logo location on some systems.
-Fixed a Crash about a network error when in safemode without networking on some OS/Systems
-*Tried* to fixed some DPI stuff.
-The extended log auto-updates again when we clean.
Translation updates :
Spanish,Russian,German,Finish (Thanks to the contributors.)
Display Driver Uninstaller 16.0.0.1
Now using WPF instead of WinForm.(1 big advantage: its DPI friendly)
New log style. (Check it out)
Added the ability to DDU to change folders permission that were failing to be removed before.
Now using SetupAPI instead of DEVCON for device removal.
Ability to alter folder and registry permission for removal. (Only for an item to be removed )
Fixed Physx was always getting removed in some part of the code.
Enhancement to the automatic language selection on first launch.
Improved overall quality of the code.
And a lot of other not really worth to mention little changes here and there.
Nvidia and AMD addition cleanUP
V16.0.0.1 Fixed a crash if "%user%\Public\pictures\nvidia corporation" does not exist.
Important note: Most of these change wouldn't have been possible without the help of a fantastic coder: "devmltk"
