Driver Talent for Network Card
About Driver Talent for Network Card:
Driver Talent for Network Card adopts all the features of Driver Talent Standard and enables users to install network drivers without Internet connection. As we know, Driver Talent Standard needs available internet connection to scan, download and install drivers. However, your network drivers would be installed when the installation of Driver Talent for Network Card is done. So even you have no access to the network, Driver Talent for Network Card can run normally. Of course, you need a computer that is able to connect to the internet to download Driver Talent for Network Card.
Kind tip: Driver Talent for Network Card (168MB) is much bigger than Driver Talent Standard (9.84MB) because Network Card version integrated all commonly used network drivers into its driver library. That is why Driver Talent for Network Card is able to install network adapter driver offline (without internet access). For common usage, like simply checking for and installing driver updates, backing up, restoring and uninstalling drivers, Driver Talent Standard is enough for you.
All features are FREE by December, 31th, 2015
Enjoy lifetime FREE if you download and activate it by Dec. 31th, 2015
