Enigma Virtual Box
Enigma Virtual Box 8.20
8.20 Build 2018.05.16
- Minor improvements
- Fixed crash of console version
8.10 Build 2018.03.01
- Improved compatibility with some files
8.00 Build 2018.02.01
- Added support for TLS callbacks
- Improved processing speed for x64 files
7.90 Build 2017.12.08
- Improved compatibility with Windows 10 Insider
- Improved compatibility running specific virtual executable files
- Fixed some problems on Windows 8-10, packed software crashed accessing virtual file
- Fixed incompatibility with some antivirus softwares
Enigma Virtual Box 9.00
version 9.00 9.00 Build 2018.06.26
- Virtual Box is much faster now!
- Added drag and drop feature for input file
- Critical core improvements for faster files and registry operations
- Improved loading speed if thousands virtual files are used
- Fixed logic of registry virtualization caused much issues with virtual registry
- Fixed memory overflow issue for GUI version when packing tons files
- Bug fixed with processing of file synchronous operations for 64 bit files
- Manual appended and fixed
Enigma Virtual Box 9.30
Version 9.30 21 Aug 2019
- Fixed problems using Share to child processes option
- Fixed problem running multiple child processes
- Fixed freezing issue on packing x64 net files
- Fixed issues running virtual x64 exe files
- Fixed problem with sharing virtual system to child x64 process
- Fixed issue with opening directory like a file, caused unexpected application behavior
- Fixed wrong alignment of relocation directory
- Improved directory listing caused exceptions in .net programs
- Added two new root paths %SYSTEM DRIVE% and %UserProfile FOLDER%
Pobieranie:
Enigma Virtual Box 9.60
9.60 Build 20210209
- Fixed issue caused application freezing on some systems
- Fixed fails of direct disk access operations
- Added compatibility of applications loading with restricted permissions
- Improved dll files loading without temporary files
- Improved handling of ZwQueryVirtualMemory function​
9.50 Build 20200225
- Improved handling of ZwQueryDirectoryFile
- Minor bugs are fixed​
Enigma Virtual Box 10.50​
10.50 Build 20231018
- Improved Windows API hooking
- Fixed issue reading virtual files
- Fixed antivirus detection on temp files while protection process
- Fixed issue reading virtual files over the end of file returning STATUS_END_OF_FILE status
- Fixed issue with ZwCopyFileChunk using non synchronous read-write operations
- Fixed issue executing large virtual exe files
- Fixed issue creating packages by console version
- Fixed loading packages for x64 files​
Enigma Virtual Box 10.70​
10.70 Build 20240522
- Fixed freezing of applications in file dialogs
- Fixed handling of ZwNotifyChangeDirectoryFile function
- Fixed loading of keys with type REG_NONE
- Fixed writing values to virtual regisitry
- Fixed packing of some files with relocation directory
- Fixed issue saving template files for Package Builder​
Enigma Virtual Box 11.10​
11.10 Build 20241106
- Fixed execution of virtual exe files under recent Windows 11
- Better handling of virtual memory of mapped virtual files
- Improvements of querying of virtual files under Windows 11​
Enigma Virtual Box 11.20
11.20 Build 20250129
- Improved handling of virtual files under Windows 11 24H2
- Added support of new API for dealing with virtual files
- Added support of file ids for virtual files
- Improved support of querying of mapped virtual memory
- Fixed problem boxing Python applications
