FanControl v178​
January 19, 2024
  • Fix a bug where sensor settings wouldn't be saved using the assisted setup.
  • Disable LHM if no sensor source is checked.
  • Change the title bar color based on current theme.
  • Update LibreHardwareMonitorLib
FanControl V181​
  • Max response time increased from 60 to 300 seconds
  • Fixed a bug where a fan would stay stuck on its default %
  • Increased the set control % when pairing with the assisted setup
  • Software now available with an installer (portable still available)
FanControl V182​
  • Controls can now be RPM calibrated.
  • Calibration can be done through the assisted setup or edited manually.
  • All fan curves can now be switched to RPM mode.
  • Controls now show their configuration status through a label.
  • .NET 7 version is now deprecated in favor of .NET 8.
  • Updated LibreHardwareMonitorLib.
