Flow Launcher 1.18.0​
Apr 22, 2024
  • Features:
  • Program plugin now shows the target path when hovering over the result
  • Context Menu's query speed has been improved for JsonRPC plugins
  • Added a new feature ReQuery to the plugin API, allowing plugin developers to reload queries in order to refresh plugin result data
  • Sound effect volume is now adjustable
  • Added a new context menu for Program plugin to open the destination folder for resutls that are program shortcuts
  • The search window will now be hidden when dragging results
  • Added a new keyboard shortcut Ctrl+Shift+C to copy the result path
  • Bug fixes:
  • Fixed an issue with Opera bookmarks
  • Fixed Custom Query Shortcut logic when two or more share the same prefix
  • Fixed Program plugin's indexer, which will now run when either Win32 or UWP application cache is empty
  • Node plugins using V2 JsonRPC now works as expected
  • Added new and updated translations
  • Reworked image caching
Flow Launcher 1.19.0​
Aug 16, 2024
  • Features:
  • Add external preview support. Preview can now be changed to use any third party preview tools via a plugin.
  • Added the ability to use QuickLook for previewing files. Look for the QuickLook plugin in the Plugin Store.
  • Explorer plugin can now open Windows native context menu via Alt + Enter or Flow's own context menu.
  • The search window can now be resized with the mouse.
  • Added support for installing plugin locally.
  • Added ability in the search window to cycle through search history with Up Arrow or Alt + Up Arrow keys.
  • Explorer plugin has a new added option to exclude specific file types.
  • Added a new option to enable/disable Everything's run count in Explorer plugin.
  • Updated Flow's error icon for better visual communication.
  • Updated Explorer plugin icons to align with design standards.
  • Added a special tray icon when running local development build.
  • Add an option to hide uninstallers from results in the Program plugin.
  • Flow's install file size has been slightly reduced.
  • Refined the hotkey system for better user experience and functionality.
  • Bug Fixes:
  • Fixed QTTabBar support. It can now be configured via settings.
  • Fixed Explorer plugin's Everything search not honouring the max number of results that should be returned. It now defaults to returning 100 results from search.
  • Fixed an issues causing partial environment variable search to not work in Explorer plugin.
  • Fixed an issue where mouse hovering over results was interfering with keyboard navigation.
  • Added new translations, including new Vietnamese language support.
  • Localized start-up messages about missing Python/NodeJS installation.
  • Fixed a minor Plugin Manager setting panel UI issue.
  • Fixed DPI scaling issues.
  • Fixed search window's display positioning in certain setups.
  • Correctly display clock and date preview in settings window based on the language selected.
  • Fixed an issue where search queries were unnecessarily re-running.
  • Tweaked minor issues in the settings window UI display.
  • Made adjustments to the preview panel for better usability.
  • Updated Program plugin's caching policy for improved performance.
  • Ensured the settings window is centered correctly on first launch.
  • Made adjustments to themes for better visual consistency.
  • Fixed ComboBox control localization in the settings window to ensure new language change is reflected immediately.
  • Fixed localization issues with ToggleSwitch controls in the settings window.
  • Localized the start-up error message about not able to register hotkey.
  • Minor fixes made to the Calculator plugin.
  • Fixed an issue where animation sound was not working due to missing Windows Media Player on user machine.
  • Added some support for screen readers to improve accessibility.
  • Fixed Shell Plugin to use shell execute.
Flow Launcher 1.19.1​
Sep 6, 2024
  • Bug Fixes:
  • Fixed Explorer plugin to show an "Enabled" column in Customize Action Keyword settings tab for better clarity over the status of action keywords.
  • Fixed Node.js path select error in settings window.
  • Translations have been added
Flow Launcher 2.1.0​
Theming​
We have moved to a new UI framework, themes with namespaces pointing to
will no longer work. Please update your themes by following the steps in this PR
Features​
  • Added a new option to show the taskbar when the search window opens.
  • New action keywords for searching only folders or files in the Explorer plugin.
  • Added an option to skip confirmation for power actions in the Sys plugin.
  • Added a new setting to disable the thousands separator in the Calculator plugin.
  • Added a max suggestion limit option to Search Query Autocomplete in the Web Search plugin.
  • Web Search plugin search sources can now be moved up and down via drag and drop.
  • New option in the URL plugin to always open URLs via HTTPS when the protocol is not specified.
  • Added support for displaying .url file icons.
  • New setting in the URL plugin to use a separate web browser profile for private mode and to manage window/tab behavior.
  • Improved Flow's startup speed.
  • Moved to a better-maintained UI Framework.
Bug fixes​
  • Fixed incomplete plugin directory deletion on uninstall.
  • Fixed an issue in the Explorer plugin where the Shell Path selection dialog opened in the wrong location.
  • Fixed search localization for the Program plugin.
  • Fixed an issue where the Custom Query Hotkey did not work when in a result's context menu.
  • Fixed a bug where the preview description was ignored when used to display text at the bottom of the preview panel.
  • Fixed incorrect text highlighting when using pinyin queries.
  • Fixed a bug that prevented the hide program function from working in the Program plugin.
  • Fixed issues with Dialogue Jump and made its handling of dialogue windows more robust.
  • Fixed issues and improved the search window's logic for handling user-typed queries.
  • Fixed an issue where using a logon startup task to start Flow caused the process to be set to low priority by default.
  • Updated missing translations.
