Foxit Reader
Foxit Reader 8.0.1.624/28
New Features in Foxit Reader 8.0
ConnectedPDF-More than PDF
Create a ConnectedPDF document
Register a new version of a ConnectedPDF document
Request a file
Configure Permissions
Join a connected review without any third-party server
Control document data and settings on the Document Homepage
Manage file access history and messages with the Personal Homepage
Dropbox integration
Supports Touch Mode when working on touch-screen devices.
Convert .msg files (emails) to PDF using the right-click context menu in Windows Explorer.
Add an option to automatically save PDF documents at regular intervals in case of system crash or power failure.
Improvements in Foxit Reader 8.0
RMS security enhancements (Enterprise Packaging only).
Preserve formatting when copying tables from PDFs.
View custom metadata in PDF.
Print PDF sections/pages directly from selected bookmark(s).
Support for SharePoint 2016 version.
Cut, delete and move multiple bookmarks at a time.
Pin the most used SharePoint, OneDrive, Google Drive, and Dropbox folders to the File > Open/Save As panels in Foxit Reader for easy access.
changelog only
DL Above :klawik.
Foxit Reader 8.0.2.805
New Features in Foxit Reader 8.0.2:
Use ADAL (Active Directory Authentication Library) authentication to log into RMS in Foxit Reader (Enterprise Packaging) to open/decrypt PDFs without requiring the installation of the Microsoft Online Services Sign-in Assistant.
Improvements in Foxit Reader 8.0.2:
Provides improvements to the ConnectedPDF feature as well as several user experience enhancements.
Issues Addressed in Foxit Reader 8.0.2:
Addressed potential issues where the application could be exposed to a TIFF Parsing Out-of-Bounds Read/Write vulnerability, which could be leveraged by attackers to execute remote code or leak information.
Addressed a potential issue where the application could be exposed to a Use-After-Free vulnerability when attempting to parse malformed FlateDecode Streams, which could be leveraged by attackers to leak sensitive information or execute remote code.
Addressed potential issues where the application could be exposed to an Out-Of-Bounds Read/Write vulnerability when parsing JPEG2000 files, which could be leveraged by attackers to leak information or execute remote code.
Addressed a potential issue where the application could be exposed to memory corruption vulnerability when parsing JPEG2000 files, which could cause remote code execution.
Addressed a potential issue where the application could be exposed to a DLL hijacking vulnerability that could allow an unauthenticated remote attacker to execute arbitrary code on the targeted system.
Addressed potential issues where the application could be exposed to a JPXDecode Out-of-Bounds Read/Write vulnerability when processing specially crafted PDF files with malformed JPXDecode streams, which could cause information leak or remote code execution.
Addressed a potential issue where the application could be exposed to an Out-of-Bounds Read vulnerability when processing specially crafted BMP files, which could cause information leak.
Addressed a potential memory corruption vulnerabilities which could cause the application to crash unexpectedly.
Foxit Reader 8.1.0.1013
Integrate Box and Alfresco:
Open and save PDF files in Box and Alfresco.
Foxit Archive Integration:
Check in and out PDFs in Foxit Archive for easier document collaboration.
ConnectedPDF Permission Control:
Allow ConnectedPDF document owners to allow or disallow other users to start Connected Reviews or create new versions.
Foxit Reader 8.1.1.1115
Improvements:
Foxit Archive plugin enhancements
Improved the workflow when saving changes made in PDF documents in Foxit Archive and enabled users to open non-PDF files in Foxit Archive.
Issues Addressed:
Fixed an issue where a date error could occur when filling in certain PDF forms.
Fixed an issue where Foxit Reader could be unresponsive when playing a large embedded video in an RMS-protected PDF.
Fixed an issue where Foxit Reader failed to save a PDF document after repeatedly adding large attachments to the PDF.
Fixed some security and stability issues
Foxit Reader 8.2.0.2051
Share comments and discussions
Post opinions or ideas on PDF documents in Discussion Board to share and discuss with others.
Enhanced collaboration with Connected Review
All comment activities on the PDF document can be viewed at a glance and filtered from a comment dashboard.
Fast web view support
Convert files as linearized PDF files that can be opened and viewed even before the whole file is downloaded.
ECM and Network Drive support
Preview non-PDF files in SharePoint and popular network drives (Google Drive, OneDrive, Box, and Dropbox) within Reader by automatically converting them to PDF.
Content Sensitive Help
Provide feature-based self-help tools that include a “Tell Me More” link that can connect you to a help center and search feature.
Foxit Cloud Reading
Provides users with seamless reading experience across platforms and devices.
All published comments can be synchronized on both desktop and mobile devices during Connected Review, letting you never miss an important message.
Convert .xps files to PDFs.
Foxit Cloud Reading
Issues Addressed in Foxit Reader 8.2
Fixed some security and stability issues.
Foxit Reader 8.3.0.14878
  • New Feature and Improvements in Foxit Reader 8.3:
  • Enhanced comment management
  • Users can filter comments by author and status, and check the total number of comments in the Comment panel.
  • Add and share inline comments online
  • Add inline comments to PDF documents at a specified location to share and discuss with other users online.
  • ConnectedPDF enhancements
  • The ConnectedPDF Review and ConnectedPDF Protection workflows have been redesigned to provide a better user experience in document review and protection.
  • Some other user-friendly enhancements.
  • Issues Addressed in Foxit Reader 8.3:
  • Fixed some security and stability issues. Click here for details.
Jarom
23 Wrzesień 2016
Foxit Reader 8.3.2.25013
Version 8.3.2
Issues Addressed in Foxit Reader 8.3.2
  • Fixed an issue where Foxit Reader PDF Printer in version 8.3.1 failed to print certain items normally.
  • Addressed a potential issue where when the application is not running in Safe-Reading-mode, it could be exposed to command injection vulnerability with abusing the app.launchURL JavaScript call to execute a local program. (ZDI-CAN-4724)
  • Addressed a potential issue where when the application is not running in Safe-Reading-Mode, it could be exposed to an Arbitrary File Write vulnerability with abusing the this.saveAs function call to drop a file to the local file system. (ZDI-CAN-4518)
  • Addressed a potential issue where when the application is not running in Safe-Reading-Mode, it could be exposed to an Arbitrary Write vulnerability with abusing the createDataObject function call to create arbitrary executable file in the local file system.
  • Addressed a potential issue where when the application is not running in Safe-Reading-Mode, it could be exposed to command injection vulnerability with abusing the xfa.host.gotoURL function call to open arbitrary executable file. (ZDI-CAN-5030)
Jarom
23 Wrzesień 2016
Foxit Reader 9.0.0.29935
Version 9.0
New Features in Foxit Reader 9.0
  • Better accessibility
    Use single key accelerators to access commands or perform some actions, improving the application accessibility to make the reading and working with PDF files more accessible.
  • Reflow upon magnification
    Reflow a PDF file to temporarily present it as a single column that is the width of the document pane, which makes the document easier to read when magnified on a standard monitor, without scrolling horizontally to read the text.
  • Find Command
    Find a command by typing the command name and bring features to your fingertips with ease.
  • Help Center
    Provide a Help Center to help users search and find online help conveniently.
  • Advanced protection – available in Foxit Reader (MSI package) only
    • Protect your enterprise data using Windows Information Protection (WIP) to guard against the potential data leakage without otherwise interfering with the employee experience.
    • Protect PDF files using the Microsoft PDF V2 IRM Specification.
    • Enhance Foxit RMS protection to make the RMS-protected files compliant with PDF 2.0.
  • Support bleed mark and overprint simulation
    • Place a bleed mark at each corner of the bleed box to indicate the PDF bleed box boundaries during printing.
    • Simulate overprinting effects for composite output.
  • Digital signatures
    • Support to export digital IDs to .fdf files.
    • Allow users to specify the font and font size and include the Foxit application version number while designing the appearance of a digital signature.
Improvements in Foxit Reader 9.0
  • Comment improvements
    • Summarize and export the highlighted text to a TXT file.
    • Format the text in the comment pop-up box.
    • Users can now track the comments that require further actions with new comment status – Deferred and Future, and filter comments by the original author.
  • Advanced search
    • Highlight all the text search results in PDF file.
    • Search for instances that match any of the keywords.
  • Streamline the PDF scan process
    Streamline the PDF scan process and allow users to output the scanning results as a new PDF file or append it to an existing PDF file.
  • PDF form enhancements
    • View and print the 2D barcode in static XFA forms.
    • Retain font properties when copying and pasting text from Microsoft Word into a text form field in Foxit Reader.
    • Allow users to import form data from a CSV file.
  • Improve the ConnectedPDF features to provide a better user experience.
  • Some other ease of use enhancements.
Issues Addressed in Foxit Reader 9.0
Foxit Reader 9.0.1.1049
Version 9.0.1
New Features in Foxit Reader 9.0.1
  • Online ink signature
    Uploads created ink signatures to Foxit ConnectedPDF Web Services, or downloads ink signatures from the Foxit ConnectedPDF Web Services to sign PDFs across devices.
  • OneNote integration
    Enables users to send PDF documents to OneNote quickly within Foxit Reader.
  • Protected View
    Provides options to open files originating from the Internet or other potentially unsafe locations in Protected View to protect users’ systems from threats.
Improvements in Foxit Reader 9.0.1
  • Accessibility improvements
    Detects assistive technology installed on the user’s computer and responds to users with prompts for more accessible reading settings, and supports reading on non-standard Windows dialogs for better experiences for vision-impaired users.
Issues Addressed in Foxit Reader 9.0.1
  • Fixed some stability issues.
Foxit Reader 9.1.0.5096
Version 9.1
New Features in Foxit Reader 9.1
  • Read and interact with PDFs by NVDA
    Enable visually impaired users to read and interact with PDFs using NVDA (NonVisual Desktop Access).
  • Show alternative text when hovering over an image
    For images with an alternative text, show alternative text when you hover your mouse over it to help you understand the image better.
  • Create custom dynamic stamp with custom values
    Create custom dynamic stamp with custom values to invoke a prompt window for users to input information while adding a stamp in PDF file.
  • Justify comment text
    Justify text while adding Callout and Text Box comments in a PDF.
Improvements in Foxit Reader 9.1
  • Deployment enhancements - available in Foxit Reader (MSI package) only
    • Use Foxit Customization Tool to embed a registration code in the MST file to enable company-wide registration during installation.
    • Use GPO templates and XML Editor to control Microsoft IRM protection version (including Microsoft IRM V1, Microsoft IRM V2, and Microsoft IRM PFile Protection) for document encryption.
    • Configure the trusted application list using GPO templates or XML Editor to deploy it across the organization.
  • Create keyboard shortcuts for the submenus in Foxit Reader ribbon.
  • Scale the page content equally based on the specified page size to deliver the best output results during printing.
  • Save the search results to PDF or CSV files for further reference.
Issues Addressed in Foxit Reader 9.1
Pobieranie:
Portable:
(trzeba odznaczyć "Download our offers")
