HandBrake
HandBrake 1.4.2
HandBrake 1.4.2
All platforms
General
  • Improvements and fixes around colour bit-depth handling.
  • Fixed various issues where incorrect colour information could be written during muxing.
Hardware Encoding
  • Fixed corrupted video output when decoding HDR10 content with QuickSync
Subtitles
  • Fixed a slight subtitle colour shift issue when using libass
Mac
  • Fixed a build system errors that could cause failures linking libbluray
  • Fixed incorrect documentation URL
  • Fixed a possible crash that can occur when applying a malformed preset.
Windows
  • Added "Preset" used to the Queue summary tab.
  • Added "Save New Preset" to the preset menu, and toolbar preset dropdown to make it easier to find. (
  • Added category headers to the presets menu when using the flat display mode.
  • Changed the log filename format back to start with the destination filename as it did with 1.3 (
  • Changed tab selection behaviour on queue when changing jobs. it will no longer reset to the first tab. (
  • Fixed a minor UI juddering effect on the queue task list when jobs start or finish (
  • Fixed calculation errors when using padding on the dimensions tab (
  • Fixed an issue where static preview wasn't live-updating when changes occurred (
  • Fixed a crash on the Audio Defaults screen whilst trying to add Tracks (
  • Fixed incorrect taskbar icon state when running multiple encodes (
  • Fixed an issue where "None" resolution limit was not honoured (
  • Fixed an issue with preset export. VideoTune was not written correctly (
HandBrake 1.5.0​
All platforms​
Video​
  • Fixed an issue on older Intel CPUs causing the CLI to fail to initialize (
  • Updated video engine to preserve chroma sample location information
  • Updated Intel Quick Sync to use the Intel oneAPI Video Processing Library (oneVPL)
Audio​
Subtitles​
Build system​
  • Fixed multiple potential race conditions in Flatpak build process
  • Updated mac-toolchain-build script with newer tool versions
Third-party libraries​
  • Updated libraries
    • FFmpeg 4.4.1 (decoding and filters)
    • FreeType 2.11.1 (subtitles)
    • Fribidi 1.0.11 (subtitles)
    • HarfBuzz 3.1.2 (subtitles)
    • Jansson 2.14 (JSON architecture)
    • libass 0.15.2 (subtitles)
    • libdav1d 0.9.2 (AV1 decoding)
    • libjpeg-turbo 2.1.2 (preview image compression)
    • libogg 1.3.5 (Xiph codecs support)
    • libvpx 1.11.0 (VP8/VP9 video encoding)
    • zimg 3.0.3 (color conversion)
Linux​
  • Fixed a filter settings issue that resulted in incorrect filters being added to jobs (
  • Updated Intel QSV Flatpak plugin to use Intel MediaSDK 21.3.5
  • Updated Flatpak dependencies
    • Freedesktop Platform 21.08
    • GNOME 41
  • Added Corsican (Corsu) translation
  • Updated translations
    • Simplified Chinese (简体中文)
    • Dutch (Nederlands)
    • French (Français)
    • Korean (한국어)
    • Spanish (Español)
    • Swedish (Svenska)
  • Miscellaneous bug fixes and improvements
Mac​
  • Requires macOS 10.13 High Sierra or later
  • Fixed potential issues where encoding process could get stuck on efficiency cores in some cases
  • Fixed an issue with automatic naming not applying correctly
  • Fixed main window not being shown upon editing a job in the queue
  • Updated queue statistics tab to include average encoding speed and percent of original file size
  • Added "Move to top" and "Move to bottom" to the queue context menu
  • Added a stop breakpoint to the queue, set when stop after job is selected and may be reordered (
  • Added native support for the VideoToolbox API, enabling advanced features such as frame multi-pass, mastering display and content light metadata, and chroma location; the previous implementation via FFmpeg's libavcodec has been removed
    • French (Français)
    • German (Deutsch)
    • Italian (Italiano)
    • Portuguese (Português)
Windows​
  • Requires Windows 10 or later and Microsoft .NET Desktop Runtime 6.0.0 or later
  • Fixed a potential crash when encoding using Intel QSV in 2-pass mode (
  • Fixed an issue with static preview not updating when switching between automatic and custom cropping modes (
  • Updated the toolbar preset dropdown to an overlay panel that utilizes a tree view which saves state
  • Updated UI with various improvements to layout, typography, and cosmetics
  • Updated queue statistics tab to include average encoding speed and content information
  • Updated automatic naming file format placeholders to be live options
  • Updated Send File To preference to set HB_SOURCE, HB_DESTINATION, and HB_EXIT_CODE environment variables, which can be used instead of arguments
  • Added new exit_code parameter to Send File To preference
  • Added support for Windows 10/11 notifications, enable in Preferences > When Done
  • Added support for Right to Left UI rendering for languages that require it. This can be set in preferences
  • Added Traditional Chinese (正體中文) translation
    • Simplified Chinese (简体中文) - includes fix for access keys in menus
    • Corsican (Corsu)
    • German (Deutsch)
    • Japanese (日本語)
HandBrake 1.6.0​
General​
  • Added AV1 video encoding
  • Added high bit depth and color depth support to various encoders and filters
  • Added 4K AV1 General, QSV (Hardware), and MKV (Matroska) presets
  • Added 4K HEVC General presets and updated related presets to use similar encoder settings
  • Revised Web presets and renamed to Creator, Email, and Social
  • Removed VP8 presets
    • The VP8 video encoder is now deprecated and will be removed in a future release
    • Related, the Theora encoder is long deprecated and will be removed in a future release
  • Miscellaneous other preset revisions
Video​
  • Added SVT-AV1 (software) and Intel QSV AV1 (hardware) video encoders
  • Added VP9 10-bit encoder
  • Added NVENC HEVC 10-bit encoder
  • Added VCN HEVC 10-bit encoder
  • Added H.264 levels 6, 6.1, and 6.2 for the x264 encoder
  • Added H.264/H.265 4:2:2 and 4:4:4 profiles for the x264 and x265 encoders
  • Added H.265 4:2:2 profile for VideoToolbox encoder on Apple Silicon
  • Added support for Intel Deep Link Hyper Encode (leverage multiple QSV media engines to increase performance)
  • Fixed longstanding issue where slowest NVENC encoder preset caused encoding failures
  • Removed support for Intel CPUs older than 6th generation (Skylake) when using Intel Quick Sync Video
Filters​
  • Added Bwdif deinterlace filter
  • Improved Autocrop filter algorithm
    • Higher accuracy on mixed aspect ratio content, e.g. both letterbox and full frame pictures
  • Improved video scaling performance on Apple Silicon and ARM-based systems
    • Use zscale (zimg) by default, falling back to swscale where necessary
  • Improved multithread performance (slightly) for the following filters on high core count systems
    • Comb Detect
    • Decomb
    • Denoise
      • NLMeans
  • Updated the following filters to support higher than 8-bit content and 4:2:2/4:4:4 chroma subsampling
    • Detelecine
    • Comb Detect
    • Decomb
    • Grayscale
    • Denoise
      • NLMeans
      • HQDN3D
    • Chroma Smooth
    • Sharpen
      • UnSharp
      • LapSharp
Build system​
  • Added support for building for OpenBSD
  • Added --cpu configure parameter to enable building for native CPU architecture
  • Added --lto configure parameter to enable link time optimization
  • Updated libraries
    • AMF 1.4.24 (AMD VCN encoding)
    • FFmpeg 5.1.2 (decoding and filters)
    • FreeType 2.12.1 (subtitles)
    • Fribidi 1.0.12 (subtitles)
    • HarfBuzz 4.4.1 (subtitles)
    • libass 0.16.0 (subtitles)
    • libbluray 1.3.4 (Blu-ray decoding)
    • libdav1d 1.0.0 (AV1 decoding)
    • libdvdread 6.1.3 (DVD decoding)
    • liblzma (xz) 5.2.6 (LZMA video decoding, e.g. TIFF)
    • libjpeg-turbo 2.1.4 (preview image compression)
    • libspeex 1.2.1 (Speex audio decoding)
    • libvpx 1.12.0 (VP8/VP9 video encoding)
    • libxml 2.10.3 (general)
    • oneVPL 2023.1.0 (Intel QSV encoding/decoding)
    • x264 164 r3100 (H.264/AVC video encoding)
    • x265 r12747 (H.265/HEVC video encoding)
    • zimg 3.0.4 (color conversion)
  • New libraries
    • SVT-AV1 1.4.1 (AV1 encoding)
Linux​
  • Added many quality of life improvements contributed by community members
  • Improved parity with the Mac and Windows graphical interfaces
  • Added new translations
    • Bulgarian (Български)
    • Finnish (Suomi)
    • Georgian (ქართული)
Mac​
  • Added Quick Look support to the queue
  • Added Japanese translation
Windows​
  • Updated all translations
    • Polish (Polski)
HandBrake 1.6.1​
HandBrake 1.6.1​
All platforms​
Video​
Command line interface​
  • Fixed inability to name external subtitles tracks using --subname
Mac​
  • Fixed behavior of quality slider when changing encoders
Linux​
  • Fixed translations missing updates as part of 1.6.0 (
    • Corsican (Corsu)
    • German (Deutsch)
    • Spanish (Español)
  • Fixed (partially) Intel QSV hardware detection (
  • Fixed a potential crash when canceling an Intel QSV encode (
  • Fixed building with -Werror=format-security by adding missing format strings where needed
Windows​
  • Fixed quality slider not allowing negative values for encoders supporting them
  • Fixed issues upgrading presets from older versions (
  • Fixed a potential graphical interface hang when stopping the queue (
  • Fixed optical disc drives on the source selection pane not scanning correctly (
  • Fixed erroneous display of 2-pass check box for Intel QSV AV1 encoder (not yet supported) (
  • Fixed a build configuration issue that broke version 1.6.0 for Windows on arm64
  • Fixed an issue that prevented NVDEC from being available
  • Fixed passthru audio erroneously falling back to encoding (
  • Fixed the Save New Preset button incorrectly overwriting recently added presets (
HandBrake 1.7.0​
Upgrade Notice​
Before updating HandBrake, please make sure there are no pending encodes in the queue, and be sure to make a backup of any custom presets and app preferences you have, as they may not be compatible with newer versions.
Windows users, please make sure to install
. Read carefully: you need the DESKTOP runtime. You must install .NET 6 even if you have installed .NET 7.
HandBrake 1.7.0​
General​
  • Added Apple VideoToolbox hardware presets
  • Updated Creator presets
    • Disabled interlacing detection and removal; assume creators are working with progressive sources by default
  • Updated Social presets
    • Target higher quality and frame rate over shorter durations, without interlacing detection and removal
    • Better suited for modern social sharing of short live action clips and screen/game captures
  • Removed Email presets in favor of revised Social presets
    • Please stop sending videos via email or use the new Social presets
Video​
  • Added AMD VCN AV1 encoder
  • Added NVIDIA NVENC AV1 encoder
  • Added support for SVT-AV1 multi-pass ABR mode
  • Added support for preserving ambient viewing enviroment metadata
  • Added QSV Rotate and Format filters
  • Improved performance on arm64 / aarch64 / Apple Silicon architectures
    • Latest FFmpeg provides faster HEVC decoding, 30% faster bwdif filter
    • New SVT-AV1 assembly optimizations provide up to 4x increase in performance
  • Improved video conversion speed by removing unneeded frame copies for better memory efficiency
  • Improved Dolby Vision dynamic range metadata pass through
    • Supported encoders: x265 10-bit
    • Supported profiles and cross-compatibility IDs: 8.4, 8.1, 7.6 (base layer only, converted to 8.1), 5.0
  • Improved HDR10+ dynamic range metadata pass through
    • Supported encoders: x265 10-bit, SVT-AV1
  • Improved QSV support on Linux (
  • Updated NVENC to not use multi-pass by default; user configurable advanced option
  • Renamed 2-pass encode option to multi-pass (
  • Fixed Intel QSV encoder outputting green video in some cases (
  • Fixed pixel format conversion slightly altering colors when using a 10-bit hardware encoder (
  • Fixed scan failures by using swscale instead of zscale when source resolution is not mod 2
  • Fixed incorrect PAR when reading from an anamorphic AV1 video track
  • Removed an artificial bitrate limit on VP9 CQ mode
Audio​
Subtitles​
  • Fixed locale settings potentially causing incorrect decimal separator in SSA headers
  • Fixed a potential issue affecting zero-duration subtitles
Build system​
  • Added Meson build system for the Linux GUI
  • New libraries
    • libdovi 3.2.0 (Dolby Vision dynamic range metadata)
  • Updated libraries
    • AMF 1.4.30 (AMD VCN video encoding)
    • FFmpeg 6.1 (decoding and filters)
    • FreeType 2.13.2 (subtitles)
    • Fribidi 1.0.13 (subtitles)
    • HarfBuzz 8.2.2 (subtitles)
    • libass 0.17.1 (subtitles)
    • libdav1d 1.3.0 (AV1 video decoding)
    • liblzma (xz) 5.4.5 (LZMA video decoding, e.g. TIFF)
    • libopus 1.4 (Opus audio encoding)
    • libjpeg-turbo 3.0.1 (preview image compression)
    • libvpx 1.13.1 (VP8/VP9 video encoding)
    • libxml 2.11.5 (general)
    • oneVPL 2023.3.1 (Intel QSV video encoding/decoding)
    • SVT-AV1 1.7 (AV1 video encoding)
    • x264 164 r3107 (H.264/AVC video encoding)
    • x265 r12776 (H.265/HEVC video encoding)
    • zimg 3.0.5 (color conversion)
    • zlib 1.3 (general)
Linux​
  • Added drag and drop support for video scanning
  • Added support for native file choosers via xdg-desktop-portal
  • Added Queue > Add All menu option
  • Added XML chapter import and export
  • Added bit depth and HDR information to video summary
  • Added option to pause encoding when switching to battery power or when power save mode is activated
  • Added automatic file naming options: {codec} {bit-depth} {width} {height} {modification-date} {modification-time}
  • Updated Queue, Activity, and Presets windows to no longer float on top of the main window
  • Updated existing translations
  • Removed obsolete update checker
Mac​
  • Added support for drag and drop of multiple files at once
  • Added support for selecting multiple files at once in the Open Source dialog
  • Added support for recursive folder scanning in the Open Source dialog
  • Added support for VideoToolbox H.265/HEVC, H.264/AVC, ProRes, and VP9 hardware decoders on macOS 13 and later
    • Enable/disable in the Preferences > Advanced tab always or full path only
    • Using hardware decoders on modern devices may decrease CPU usage and thus speed up some filters and encoding
  • Added GPU accelerated Crop & Scale, Rotate, Pad, Yadif, Bwdif, Chroma Smooth, Unsharp, Lasharp, Grayscale filters
  • Added "Same as source" destination option that automatically sets the destination path to the source path
  • Improved SVT-AV1 encoding performance by up to 4x on Apple Silicon Macs
  • Improved automatic file naming Preferences UI and added new options: {width} {height} {quality_type} {encoder_bit_depth} {modification-time} {modification-date} {codec} {encoder} {encoder_bit_depth} {preset}
  • Improved handling of security scoped bookmarks
  • Fixed Chroma Smooth tune options
  • Fixed Deblock Filter custom string field
  • Fixed an issue that prevented the VideoToolbox "speed" preset from being used
  • Fixed the file size display on the queue statistics window when file size info is not available
    • Korean (한국어)
Windows​
    • Enable/disable in Preferences > Advanced
  • Added support for excluding file extensions when opening files in batch mode
    • Default exclusions are common image, subtitles, and text file extensions; edit list in Preferences > Advanced
  • Improved Preview window native video playback to support most containers and codecs
    • Modern codec support requires Microsoft Codec Packs from the Microsoft Store
  • Improved automatic file naming Preferences UI and added new options: {width} {height} {quality_type} {encoder_bit_depth} {modification-time} {modification-date} {encoder} {encoder_bit_depth} {preset}
  • Improved Queue window UI to optionally show additional status information on the left progress panel
  • Improved Presets panel
    • Manage Presets button replaced with a menu of discrete options for quicker access to functionality
    • Added an option to display the description for the selected preset
    • Added the ability to clone a preset (create a new preset based on an existing one)
  • Improved Add Selection window to make sorting feature more discoverable
  • Improved Process Isolation reliability
  • Fixed automatic file naming when using physical drive sources (
  • Fixed Title Specific Scan for physical drive sources (
  • Fixed an potential issue that could cause an unmodified preset to display as "modified" (
  • Fixed an potential issue where changes to queue order were not retained (
  • Fixed an Audio tab issue where using a non-fallback encoder could lead to duplicated tracks (
  • Fixed an issue where swapping graphics cards might cause hardware presets to be incorrectly shown as disabled
  • Fixed a potential crash on startup related to Windows Notifications Service failures (
  • Czech (česky) (partially complete)
  • Greek (Ελληνικά) (partially complete)
  • Estonian (Eesti) (partially complete)
  • Basque (Euskara)
  • Finnish (Suomi) (partially complete)
HandBrake 1.7.1​
HandBrake 1.7.1​
Video​
Mac​
HandBrake 1.7.2
HandBrake 1.7.2
Video
  • Improved automatic selection of Dolby Vision Level
  • Fixed an issue in AMD VCN, MPEG-2, MPEG-4, NVIDIA NVENC, and VP9 encoders that could cause the creation of an excessive number of keyframes (
  • Fixed unintentional automatic pass through of closed caption side data when using NVIDIA NVENC encoder
Linux​
  • Improved performance by removing duplicate graphic assets and reducing file size
  • Fixed Flatpak file chooser opening home directory instead of the previously selected directory
  • Fixed last item in the queue sometimes having the wrong destination path
  • Fixed some memory leaks in the graphical interface
Mac​
  • Added a workaround to prevent a system crash when using VideoToolbox encoders with macOS 14 Sonoma on Apple Silicon Ultra
  • Added a workaround to prevent issues decoding H.264 video by disabling VideoToolbox hardware decoding for Level 6.1 and 6.2
  • Fixed a crash opening an empty folder
Windows​
HandBrake 1.7.3​
All platforms​
General​
  • Fixed formatting leading zeros for timestamps in logs
Video​
  • Fixed an issue that could potentially cause incorrect detection of source FPS value (
Subtitles​
  • Fixed tx3g to SSA subtitles conversion
Linux​
  • Fixed the "All Files" open file dialog filter to really show all files
  • Fixed an issue where adding a new default audio track automatically set the gain to -20 dB
macOS​
  • Fixed a regression introduced in HandBrake 1.7.2 by the workaround for VideoToolbox crashes on Sonoma
Windows​
  • Improved security hardening of loading of DLL files within libhb by limiting search scope (
  • Improved keyboard navigation on Chapters tab (
  • Fixed an issue that could cause encodes to appear stalled when process isolation is turned on
  • Fixed an issue that could prevent QSV decode from being used when a system also has a non-Intel GPU
  • Fixed an issue where the drive label was not always correctly detected (
HandBrake 1.8.0​
All platforms​
General​
  • Allowed muxing VP9 and FLAC in the MP4 container
  • Removed timestamp jitters when using a constant NTSC frame rate in the MP4 container
  • Removed support for importing legacy plist based presets from much older versions of HandBrake
  • Updated iso639 language codes list
Video​
  • Added support for the FFV1 encoder, including a new preset "Preservation FFV1" under the Professional category
  • Added support for multi-pass CQ with VP9
  • Added support for VP9 tunes
  • Added Dolby Vision dynamic metadata pass through for SVT-AV1
  • Improved Decomb speed by removing unneeded frame copies
  • Improved Framerate Shaper metrics for high depth frames
  • Fixed subtitle "scan" when not first in --subtitle list
  • Fixed override of subtitle settings
  • Fixed processing audio overrides to preset
Audio​
  • Added TrueHD encoder
  • Added 88.2/96/176.4/192 kHz sample rates for TrueHD and FLAC encoders
  • Improved audio tracks selection by tracking "linked" audio tracks
  • Fixed incorrect channel layout when encoding a 6.1 track to Opus
Subtitles​
  • Fixed passthru of VobSub tracks that contains empty of fully transparent subtitles samples
  • Fixed an issue that prevented decoding VobSub tracks stored inside MP4
  • Fixed burn-in of SSA/ASS subtitles inside MKV that have duplicated Read Orders
Build system​
  • Reviewed and improved compiler optimization options for the third-party libraries
  • Improved libdovi package to make it possible to ship it in Flathub flatpak version
  • Updated libraries
    • AMF 1.4.33 (AMD VCN video encoding)
    • FFmpeg 7.0 (decoding and filters)
    • HarfBuzz 8.4.0 (subtitles)
    • libass 0.17.2 (subtitles)
    • libdav1d 1.4.1 (AV1 video decoding)
    • libdovi 3.3.0 (Dolby Vision dynamic metadata)
    • libopus 1.5.2 (Opus audio encoding)
    • libjpeg-turbo 3.0.3 (preview image compression)
    • libvpx 1.14.0 (VP8/VP9 video encoding)
    • oneVPL 2.10.1 (Intel QSV video encoding/decoding)
    • SVT-AV1 2.1.0 (AV1 video encoding)
    • x264 164 r3186 (H.264/AVC video encoding)
    • x265 3.6 (H.265/HEVC video encoding)
    • zlib 1.3.1 (general)
  • Removed libraries
    • libxml2
Linux​
  • Migrated the UI to GTK 4
  • Added support for resursive file scan
  • Added support for drag/drop/multi-file scanning. (Including subtitle files)
  • Added --clear-queue and --auto-start-queue flags to the linux ui app.
  • Update the "Open Source" button to make the folder/batch mode more discoverable.
  • Refreshed app icons
Mac​
  • Added Dolby Vision and HDR10+ dynamic metadata pass through for VideoToolbox H.265 10-bit
  • Added Metal accelerated Comb Detect and Framerate Shaper filters
  • Added ability to drag and drop SRT and ASS subtitles files onto the main window
  • Added new preference to pause encodes when switching to battery
  • Added new preference to clear completed jobs at launch option
  • Reworked notification options to allow per encode or per queue control
  • Reworked toolbar to follow macOS UI style
  • Improved performance of the Activity Log window
  • Improved UI performances by avoiding uneeded window resizes and slow AppKit controls
    • Ukrainian
Windows​
  • Requires Microsoft .NET Desktop Runtime 8.0.x
  • Added Invert Queue option to the Add to Queue Window (
  • Drag/Drop now supports resursive folder scan mode.
    • Catalan (Català)
HandBrake 1.8.1​
HandBrake 1.8.1​
All platforms​
Video​
  • Fixed a warning / misconfiguration when repeat-headers is used with the x265 encoder.(
  • Fixed an issue where the NVEnc encoder ignored the level option
Subtitles​
  • Fixed an issue where dvd subtitles could be corrupted during rendering.
Filters​
  • Updated libraries
    • FFmpeg 7.0.1 (decoding and filters)
    • libdav1d 1.4.3 (AV1 video decoding)
Mac​
  • Fixed a stall in the queue that could happen if the encoding process crashes when configuring a job
  • Removed the "Show" button from the notifications when there is nothing to show
Windows​
  • Hardware decoding is now defaulted to off for new installations. Users can opt-in whilst making sure they are running up-to-date drivers
  • Fixed an issue where hardware decoding could erroneously be used for previews
  • Fixed an issue where auto name was triggering too aggressively (
  • Removed an erroneous error message when dragging files onto the main window that include a subtitle file.(
HandBrake 1.8.2
All platforms
General
  • Fixed a potential crash when trying to scan deleted files
  • Fixed scan of broken video that uses reserved color matrix values
  • Fixed an issue that could cause some audio tracks to be dropped
  • Updated libraries
    • FFmpeg 7.0.2 (decoding and filters)
    • libass 0.17.3 (subtitles)
    • libvpx 1.14.1 (VP8/VP9 video encoding)
Windows
  • Fixed an issue where auto name wasn't triggering correctly with preset changes (
  • Fixed a potential crash when importing presets from the mac version. (
  • Fixed an issue loading presets where a video encode isn't available on the system. (
  • Minor startup performance improvement on some Intel based systems.
Linux
  • Fixed an issue where an encoded file could be output to the wrong filename when using the queue (
Mohammad.Poorya
19 Wrzesień 2018
On a Bike!
HandBrake 1.9.1​
All platforms​
General​
Subtitles​
Audio​
  • nv-codec-headers: Harden DLL loading so that it only uses system32 for the search path on Windows (
  • Updated libraries
    • libdav1d 1.5.1 (AV1 video decoding)
    • HarfBuzz 10.2.0 (subtitles)
    • libjpeg-turbo 3.1.0 (preview image compression)
Windows​
  • Fix an issue with the autoname function not updating when title is the only option (
  • Fix an issue where the audio encoder may not display correctly after a queue has been imported and queue item edited. This may exhibit in other scenarios as well (
  • Fix an issue with titlebar / taskbar progress erroneously showing with multi-instance encodes (
  • Fix a crash when importing chapters where there is a chapter count mis-match (
  • Fixed an issue with autoname pre/postfix option where it would apply regardless of file path collision.
  • Fixed an issue where the crop controls would not enable correctly when editing jobs (
Mohammad.Poorya
19 Wrzesień 2018
On a Bike!
HandBrake 1.9.2
Febuary 23, 2025
The HandBrake Team is pleased to announce the release of HandBrake 1.9.2
This release is a small maintenance release that resolves a few common issues with the 1.9.1 release and updates a few third party libraries.
All platforms
General
  • Allowed muxing NVENC AV1 and VCN AV1 WebM container
    Fixed a crash that could happen when a source contains chapters with no titles (
Windows
  • Fixed and issue where the audio track name would not reset on source track change. (
News:
DL Page (All OS)
zip
exe
Podobne tematy:
