Monkey's Audio 7.66​
May 5, 2022
  • Fixed: The information dialogs in MACDll didn't show in the 64-bit version since the DLL was renamed.
New in Monkey's Audio 7.65​
  • Fixed: A resource file got changed in a bad way due to the Cool Edit change.
Monkey's Audio 7.69​
May 11, 2022
  • Fixed: Made WAV files with sizes that were not divisible by the block size round down to the nearest block instead of error.
  • Fixed: Too large files could overflow the number of audio blocks (switched from signed to unsigned to support double the number of blocks).
helium
16 Czerwiec 2010
Kurde, mają rozmach z tymi aktualizacjami :) Nie raz, to nawet dwa razy dziennie.
Monkey's Audio 7.80​
June 2, 2022
  • Changed: Enabled warning 4840 and worked through the warnings.
  • Changed: Removed the little uninstall launcher and just call the main program with a switch instead.
  • Fixed: The uninstall icon was not showing the Monkey's Audio icon.
