Multi Commander 15.7.0 Build 3130​
  • FIXED - Error when unpacking rar that contains hardlinks
  • ADDED - Audio can be be played in Loop. Setting in Audio Popupmenu and "Loop" Option added to MC.PlayAudio custom command
  • ADDED - Workaround to make MultiCommander start on Windows 7. (Might be temorary until better solution is decided)
  • ADDED - Increased the max number of UserDefinedCommands that can be registered for Menu/Toolbar from 600 to 950
  • ADDED - Improved logging in FSSFTP when it fails to connect
  • ADDED - Extended logging for drop file operation to be able to figure how why it does not work when it fails
  • ADDED - Startup can now be configured to NOT load things in parallel. (Slower but might fix rare startup issues)
  • ADDED - Extended column that show real filesize for compressed and spare files
  • ADDED - Video properties from MCVideoTool extension will now refresh there cached value if force refresh is called for
  • ADDED - Improved error message for file operation error "Unknown error" Often it is a Windows error code that is not handled. Will now show Windows Error text for that too.
  • FIXED - FS-SFTP - Fixed issue removing proxy settings from a site profile
  • FIXED - Drag/Drop of files using internal MC drop data now works again.
  • FIXED - Saving of tabs to remember got deleted after they was saved during shutdown of MC.
  • ADDED - Improved error logging to couple of places.
  • CHANGE- Major code cleanup and restructing of codebase for core parts of MultiCommander
  • FIXED - Issue when opening archive (zip/7z/rar) on network path ( eg \SeverSharefile.zip ), It was not always closed correctly after use
  • FIXED - Alias editor did not save the filtered view after sorting columns.
  • FIXED - 18+ possible stability issues
Multi Commander 15.8 Build 3135​
v15.8 ( build 3135 ) - 2026-02-02
FIXED - Fixed a minimum size for filename column
FIXED - FSPortable crash issue on shutdown
FIXED - MultiDataViewer issue when searching backwards
FIXED - Ctrl+C / Ctrl+V now works from search result volume (RES#:)
FIXED - 4 Stability issues
Multi Commander 16.5 Build 3215​
V16.5 RELEASE (Build 3215) - 2026-09-11
ADDED - WebView and what formats should be opened in WebView can now be configured in Options in FileViewer.
FIXED - Linked navigation now works again. Can be enabled from View mode popup.
FIXED - Delete did not update parent folder size if folder had been calculated before.
ADDED - 10+ Stability issues
ADDED - ==========================================================
MultiCommander is now digitally signed. The installer and all program
files are code signed, so Windows shows the publisher name instead of
the "Unknown publisher" warning, and security software is less likely
to block them. Funded entirely by user donations - thank you!
