plateVerb plugin is a free for limited time.
Notice:
$1 off will be applied at checkout:
plateVerb is a stereo plate reverb plugin with simple controls. Loaded with a High Pass Filter, Low Pass Filter, and controllable Decay of the convolution.
You can also control the dry and wet signal levels separately. The Mono switch lets you set everything to mono, and the Bypass switch is there to quickly turn the effect on and off.plateVerb's versatility can bring life to any source.
All settings can be saved and loaded in your sessions as well as crossplatform presets. All parameters offer automation control to get the most expressive sound.
plateVerb is a macOS, Windows, and soon to be iOS compatible stereo plate reverb. Designed for VST3, AU, AUv3, and stand-alone use.
Notice:
