Power Sound Editor Deluxe za darmo
Power Sound Editor Deluxe v8.7.5
Power Sound Editor Deluxe to prosty w obsłudze program który pozwala na przeprowadzanie wielu różnych operacji na plikach audio.
Power Sound Editor Deluxe is easy-to-use and well-organized audio software to perform various operations with audio data. It helps you transfer tapes, LPs, live performances, Internet radio, TV, DVD, or any other sound source to your hard drive. The software helps protect your valuable recordings – just set the sound source, the recording quality, and volume, then start recording. You can create and edit audio files professionally, by having ability to apply dozens of amazing effects to audio files.
