Reg Organizer wersje stabilne
Reg Organizer 9.10​
Changes in Reg Organizer 9.10 (2022-12-29):​
  • You may configure some cleanup locations by clicking the button directly on the corresponding item in the list Previously to do this, it was necessary to go to the settings window.
  • Optimization for high resolution monitors: The list of cleanup locations now fills the window’s space both in width and height.
  • You can view cleanup locations for which the additional explanation is available by clicking the question mark icon.
  • Some icons have been redrawn to support the dark theme better.
  • New cleanup locations added: Additional Web Cache and cleaning the cache of the 4 new applications.
  • The “System Activity Logs”, “Program Crash Dumps” and “Program Error Reports” cleanup locations find more data.
  • The Private Data Cleanup tool has been switched to multithreaded scanning and has been accelerated. Scanning is now 2-3 times faster.
  • New tweaks added: “Microsoft Edge: Don’t show the page restore request after the browser crash” and “Applications’ scrollbar width”.
  • Applications tool: Improvements to the applications traces lookup algorithm.
  • You may enable the main window’s title system look that depends on the theme color by creating in the registry key HKEY_CURRENT_USERSOFTWAREChemTable SoftwareReg OrganizerSettingsEx the integer value SystemTitle equal to 1.
Bugs fixed:
  • The Reg Organizer command did not appear in the Explorer context menu under Windows 11 Insider Preview, Dev channel.
  • Application installed with tracing did not appear in the installed apps list if they cannot not be uninstalled with the standard uninstaller.
  • The Previous System Restore Points cleanup location was not cleaned.
  • The “Always show this screen at program startup” switch in the Express Check and other switches across the program might not work the proper way.
  • When you pressed the minimize and maximize system buttons in the upper right main window corner, the color was different from the system buttons’ color.
Reg Organizer 9.30​
September 20, 2023
  • Uninstalling multiple applications at once is now faster. If you choose to uninstall multiple applications at once, you only have to go through the uninstall screens once, rather than repeating the same steps for each application you want to uninstall.
  • These options became available for some applications during uninstall:
  • Speed Up the Standard Uninstaller by Hiding Unnecessary Windows.
  • Standard Uninstaller Only. No Traces Lookup.
  • Forced Uninstall: No Standard Uninstaller.
  • When uninstalling applications, an extra screen has been removed that suggested searching for their traces in the system. Now the search starts automatically when the standard uninstaller finishes, and you will shortly see the number of application traces found in the system.
  • A search field to find the item you are interested in was added to the cleanup location's items browsing window.
  • Alphabetical sorting when you click the list columns in the System Cleanup and Private Data Cleanup settings sections.
  • Bugs fixed:
  • Installing applications with tracing could hang or fail immediately after launch (due to the influence of drivers of certain applications).
  • When reopening the application installation with the tracing window, the button at the bottom had the wrong text ("Finish" instead of "Forward").
  • When you uninstall an application using the Applications tool, you may receive an unnecessary duplicate notification that the application has been deleted.
  • Applications tool: When filtering applications using the search box, some items were missing from the list.
  • When renaming a key in the registry editor, it was copied instead.
  • Startup Applications tool: It was impossible to remove RunOnceEx type items.
Reg Organizer 9.40​
February 5, 2024
  • New feature: Scheduled (background) cleaning. If enabled, the program can run periodically in the background and report when it is possible to free some disk space.
  • The Maximum cleanup mode of the System Cleanup tool now finds more unnecessary files. This is made possible by automatically adjusting the cleanup locations settings to free up the maximum amount of space when this mode is activated. In the previous version, the same cleanup locations settings were used for both the normal and Maximum cleanup modes, with the only difference being the set of cleanup locations they targeted.
  • Added an option to increase the safety of System Cleanup: "Remove only files older than 24 hours from the temporary folder".
  • The Obsolete Downloads location scan has been speeded up.
  • While performing the background tasks the tray icon is animated.
  • Improved the update checking mechanism for Autorun Organizer itself.
  • Bugs fixed:
  • The cleanup block on the Express Check screen could hang.
  • Disabled startup applications were not excluded from optimization recommendations.
  • Sometimes, right after running the cleanup, the Express Check would show that the cleanup is still recommended.
  • The program failed to close Yandex Browser before deleting its cache or other cache or other data during system cleaning.
  • Fixed white flickering in the Dark theme when switching to the final cleanup screen.
  • In the registry editor, above the list of search results, a black rectangle could appear.
