Remote Process Explorer
martini
With Remote Process Explorer, you will be able to not only get the list of processes but also manage them. You can kill a process, run a new one or change the priority of a process on a local or remote computer. To do it, you do not have to install additional software on a remote computer because the program uses the built-in functions of the operating system. Remote Process Explorer will show you complete information about each running process, when and by whom this process was run, the path to its executable file, how much memory and CPU it uses. You can get all information available in Task Manager not only for your computer, but also for a remote one.
Remote Process Explorer has tools for managing a remote computer built into it. You can switch off a remote computer, restart it or send a message to it. You can also use the standard tools for administering a computer: Remote desktop, Computer management, Event viewer, etc
Rejestracja
Pobieranie
