Remote Process Explorer
With Remote Process Explorer, you will be able to not only get the list of processes but also manage them. You can kill a process, run a new one or change the priority of a process on a local or remote computer. To do it, you do not have to install additional software on a remote computer because the program uses the built-in functions of the operating system. Remote Process Explorer will show you complete information about each running process, when and by whom this process was run, the path to its executable file, how much memory and CPU it uses. You can get all information available in Task Manager not only for your computer, but also for a remote one.
Jarom
23 Wrzesień 2016
Remote Process Explorer 5.0.0 Build 233
Remote Process Explorer 4.3.0 Build 209
  • Fixed: Sometimes an error occurred when process has been checked
  • Fixed: small bugs fixed
Remote Process Explorer 4.2.0 Build 205
  • Added: Export graphs to file
  • Modified: Export process list to file
Remote Process Explorer 4.1.0 Build 201
  • Added: Support for Windows 10
Remote Process Explorer 4.0.0 Build 193
  • Added: Process filter by name, CPU usage, Memory usage
  • Added: Columns and charts for I/O Read Bytes/s, I/O Write Bytes/s
  • Added: Autoclosing an error message window after 30 sec of waiting
  • Fixed: Impossibility to get process list after long time working (one day or more)
  • Fixed: Daylight savings
Remote Process Explorer 3.3.0 Build 175
  • Added: New "Add computers wizard". Added import computers from Active Directory, IP range, text file.
  • Added: New charts. Memory usage, handles, threads.
  • Added: Autoscale option for charts.
  • Added: Added progress bar for CPU usage column.
  • Fixed: full expand nodes in process tree after changing sorting type.
  • Fixed: small bugs fixed.
Remote Process Explorer 3.1.0 Build 151
  • Added: Command line parameters e.g. "rpexplorer 192.168.1.2", "rpexplorer 192.168.1.2 -u:Admin -p:AdminPassWord" or "rpexplorer -?"
  • Added: option to hide default charts
  • Added: Menu Network tools
  • Added: Manage Network and Administrative tools
  • Updated: Menu Copy to clipboard
  • Updated: Menu Administrative tools
  • Fixed: Memory used by the process was displayed incorrectly in case of used memory value is more than 2GB
  • Fixed: error on start program
  • Fixed: Error in drag-on-drop operation. You could not drop a node to itself.
Remote Process Explorer 3.0.0 Build 141
  • Remote Process Explorer has been completelly redesigned
  • Added: More accurate calculating CPU usage
  • Added: Graph CPU and Memory usage
  • Added: New command - Reconnect, Connect as, Default credentials
Aby skorzystać z darmowej wersji tego programu, należy zarejestrować się na stronie:
Jarom
23 Wrzesień 2016
Remote Process Explorer 5.1.0 Build 245
  • Added: Incremental search in computer list
  • Added: Column Memory Usage, %
  • Added: Filter processes by Memory Usage, %
  • Fixed: Retrieve information for Terminal Service Settings on System Information tab
Pobieranie itd. jw.
