- Dołączył
- 26 Maj 2015
- Posty
- 19243
- Reakcje/Polubienia
- 56091
Element 1.9.5
Pobieranie:Version 1.9.5 released 12 hours ago:
Features
Bug Fixes
- Make double-clicking the PiP take you to the call room
- Add maximise widget functionality
- Add rainfall effect
- Add root folder to zip file created by export chat feature
- Improve VoIP UI/UX
- Unified room context menus
- In forgot password screen, show validation errors inline in the form, instead of in modals
- Implement more meta-space
- Expose power level control for m.space.child
- Forget member-list query when switching out of a room
- Do pre-submit availability check on username during registration
- Adjust recovery key button sizes depending on text width
- Fix bulk invite button getting a negative count
- Fix maximised / pinned widget state being loaded correctly
- Don't reload the page when user hits enter when entering ban reason
- Fix timeline text when sharing room layout
- Fix look of emoji verification
- Fixes element not remembering widget hidden state per room
- Don't keep spinning if joining space child failed
- Guard around SpaceStore onAccountData handler prevEvent
- Fix missing spaces in threads copy
- Fix hover tile border
- Fix quote button
- Fix space panel layout edge cases
- Update powerlevel/role when the user changes in the user info panel
- Fix avatar disappearing when setting a room topic
- Fix possible infinite loop on widget start
- Use device IDs for nameless devices in device list
- Don't re-sort rooms on no-op RoomUpdateCause.PossibleTagChange
